Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
Sketch uses 1144 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Kelvin\AppData\Local\Temp\arduino_build_242051/Fade.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
An error occurred while uploading the sketch
option enabled in File -> Preferences.
pert
June 10, 2021, 4:07pm
2
Is the output always the same like that, or when you try it again is there sometimes more information in between the "Overriding Baud Rate : 115200" and the "An error occurred while uploading the sketch"?
I ask because we usually get some helpful error messages that allow us to determine the cause of the upload failure. But in this case there isn't any information to work with.
Tried uploading an empty setup and loop sketch and this was the responds
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Kelvin\AppData\Local\Temp\arduino_build_819871/sketch_jun10a.ino.hex:i
Using Port : COM6
Error downloading https://downloads.arduino.cc/packages/package_index.json
system
Closed
October 8, 2021, 4:28pm
4
