An error occurred while uploading the sketch 1.6.12, Blink to OSEPP Pro
I’m new to programming for a Microcontroller.
Trying to up load the Blink that came with the Arduino sketch.
Operating system: windows 10
Board: OSEPP Pro
Communicating with: OSEPP FTDI
I have change baud rates.
I have started Sketch then the board and the board then the sketch.
I have pushed the reset button at different sequences.
The error message is:
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Wilmu\AppData\Local\Temp\arduino_build_450028/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
Thanks for any help,
Scott
Problem solved. The getting started document for the "Arduino Pro" shows the SparkFun FTDI Basic Breakout Board shows the USB mini-B connector facing up. However, the one that I have has the connection with the USB mini-B facing down. I discovered this when I took a close look at the silk screen on the two boards. To take from this, despite the good intentions of the images always verify the silks screen and align according.
Just for my interest: You managed to press the USB plug upside down into the connector?
