Hi, I am new to arduino, so my commented codes are a bit messy, please ignore the // comments.
My code is:
int sensePin = PF1;
int sensePin1 = PF2;
// the analogue pin number
void setup(){
analogReference(DEFAULT);
void loop(){
int sensorvalue = analogRead(sensePin);
int sensorvalue1= analogRead(sensePin1);
float voltage = sensorvalue * (5.0 / 1023.0);
float voltage1 = sensorvalue1 * (5.0/1023.0);
Serial.println(voltage);
Serial.print(",");
Serial.println(voltage1);
The error message is (it is quite long, I turned on the 'show verbose output during compilation'):
Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\yis27\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\yis27\AppData\Local\Temp\arduino_build_624741 -warnings=none -build-cache C:\Users\yis27\AppData\Local\Temp\arduino_cache_773624 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\emg sensor\AnalogInput\AnalogInput.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\yis27\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\yis27\AppData\Local\Temp\arduino_build_624741 -warnings=none -build-cache C:\Users\yis27\AppData\Local\Temp\arduino_cache_773624 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\emg sensor\AnalogInput\AnalogInput.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\sketch\AnalogInput.ino.cpp" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\sketch\AnalogInput.ino.cpp" -o "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\sketch\AnalogInput.ino.cpp" -o "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\sketch\AnalogInput.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\yis27\AppData\Local\Temp\arduino_cache_773624\core\core_arduino_avr_mega_cpu_atmega2560_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.elf" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741\sketch\AnalogInput.ino.cpp.o" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/..\arduino_cache_773624\core\core_arduino_avr_mega_cpu_atmega2560_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\yis27\AppData\Local\Temp\arduino_build_624741" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.elf" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.elf" "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\yis27\AppData\Local\Temp\arduino_build_624741/AnalogInput.ino.elf"
Sketch uses 3940 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 202 bytes (2%) of dynamic memory, leaving 7990 bytes for local variables. Maximum is 8192 bytes.
An error occurred while uploading the sketch
Thanks for the help in advance. Let me know if I chose the wrong category.
