I have a newly installed Intel Edison and Arduino IDE software, I have installed the necessary drivers to upload scripts to the Edison, but every time I try to upload the file, I get this:
Arduino: 1.6.13 (Windows 10), Board: “Intel® Edison”
Sketch uses 76,331 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
#!/bin/sh
starting download script
Args to shell: C:\Users\timothy\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\timothy\AppData\Local\Temp\arduino_build_899659/Blink.ino.elf COM1
clupload script to invoke lsz
COM PORT 1
Copyright (C) 2014 Intel Corporation
Converted COM Port COM1 to tty port /dev/ttyS0
Sending Command String to move to download if not already in download mode
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo “starting download script”
echo “Args to shell:” $*
ARG 1: Path to lsz executable.
ARG 2: Elf File to download
ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\//}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy → /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo “COM PORT” $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo “Converted COM Port” $com_port_arg “to tty port” $tty_port_id
echo “Sending Command String to move to download if not already in download mode”
echo “~sketch downloadEdison” > $tty_port_id
C:\Users\timothy\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS0: No such device or address
#Move the existing sketch on target.
echo “Deleting existing sketch on target”
“$fixed_path/lsz.exe” --escape -c “mv -f /sketch/sketch.elf /sketch/sketch.elf.old” <> $tty_port_id 1>&0
C:\Users\timothy\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS0: No such device or address
Execute the target download command
#Download the file.
host_file_name=$2
“$fixed_path/lsz.exe” --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\timothy\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS0: No such device or address
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
echo “Moving downloaded file to /sketch/sketch.elf on target”
“$fixed_path/lsz.exe” --escape -c “mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf” <> $tty_port_id 1>&0
C:\Users\timothy\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS0: No such device or address
An error occurred while uploading the sketch
Please help.
