an error occurred while uploading the sketch
Hi,,
I have been trying to upload a (4 line ) sketch into Arduino UNO but all each time I try to upload this message shows :
Note: I try to update the port- reinstall the IDE- check my connection.
Arduino: 1.8.1 (Windows 8), Board: "Arduino/Genuino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\NORAAL~1\AppData\Local\Temp\arduino_build_190342/empty.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x66
avrdude done. Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
(deleted)
thank you so much
i have the problem too..can you help me
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1586 bytes (4%) of program storage space. Maximum is 32256 bytes.
java.io.IOException: Cannot run program "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 8 more
MarAKA:
... 8 more
You don't have the same problem!
Read the troubleshooting guide.
