An error occurred while uploading the sketch
Arduino: 1.6.13 Win7-64bit, Board: "Arduino/Genuino Uno" and " EasyVR-3"
I tried to upload TestEasyVR but it had an error during uploading.
Does anyone know how to solve it? Please help. I would like to build prosthetic hand to use voice control instead of muscle for whoever need it but I get stuck here.
Build options changed, rebuilding all
Sketch uses 11,342 bytes (35%) of program storage space. Maximum is 32,256 bytes. Global variables use 564 bytes (27%) of dynamic memory, leaving 1,484 bytes for local variables. Maximum is 2,048 bytes. An error occurred while uploading the sketch
Thank you!
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the process fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Hi, After I followec your advice, I got the below error. Could you help to lead me how to solve it please? Thanks! Kuquang
Arduino: 1.6.13 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\home\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\home\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\home\AppData\Local\Temp\arduino_build_466452/TestEasyVR.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\home\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
option enabled in File -> Preferences.
the attached file is the code that I used for Arduino and EasyVR 3.
Thanks,
Kuquang
EasyVR 3.txt (16.9 KB)
Just to try to help until someone with more knowledge than I comes along:
  1. Are you sure the device is on COM3? The way I test is to remove the Arduino, then open up the port selection menu. Note any ports that show. Now connect the Arduino and repeat. The Arduino is connected to any new port that appears.
  2. Ensure that nothing is connected to pins 0 & 1 when you are trying to upload.
Hi, Yes, it is COM3. After I unplugged EasyVR 3 shield from Arduino Uno board, I could program it. I can add and train command successful after re-plug EasyVR 3 shild back.
Thanks for all your help!!!
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaf
Executing command: exit status 1
hi i am using the arduino uno i am trying to upload a program but the program was not uploading and it show the error of
System wide configuration file is “C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM13
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x47
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
please help me to solve this problom
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM13 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x47
