It was working good, and after I came back from lunch, it crashed and told me.
Send auto-baud
Set binary mode
No device found on COM4
An error occurred while uploading the sketch
I tried to erase it but doesn't work(even not sure if it is erased).
Can anyone helps me?
many thanks
Thanks for your reply!
I am using a Arduino Due with IDE 1.8.3.
Well the error message is pretty long and I'll show it in attachment.
And for the light on the board, ON(green) and L (orange) light are always on.
I'm not sure if board is dead, but I can still read borad info from ide
yes that is what confuses me.
I can see Arduino Due programming port(COM6) from device management, also from IDE-Tools it shows
port:"COM6(Arduino Due(programming port))". But once I want to upload, such error occurs.
:o Sorry that was because I changed a computer thus programming port also changed.
I have just done what you suggest, and got same error.
Sketch uses 22124 bytes (4%) of program storage space. Maximum is 524288 bytes.
Forcing reset using 1200bps open/close on port COM6
C:\Users\Shawn\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino/bossac.exe -i -d --port=COM6 -U false -e -w -v -b C:\Users\Shawn\AppData\Local\Temp\arduino_build_681245/sketch_jul18a.ino.bin -R
Send auto-baud
No device found on COM6
Set binary mode
Suddenly stop working.
Sketch uses 27420 bytes (5%) of program storage space. Maximum is 524288 bytes.
C:\Users\Eduard\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino/bossac.exe -i -d --port=COM6 -U false -e -w -v -b C:\Users\Eduard\AppData\Local\Temp\arduino_build_537160/ShutterSynchro.ino.bin -R
Send auto-baud
Set binary mode
So instead of helping you provide no information, whatsoever.
'If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.'
After googling this problem, my first result is this link, with no one providing answers. Solid use of google yes, thank you for the help. (Obviously not). Very intelligent person, (Obviously not).
