An example code created to help beginners with the syntax of using sequences in their code
// This code demonstrates the correct use of while statements and sequences that neaten your code.
void CODEsequence(); // Part of the setup of your sequences
void CODEsequence2();
const int switchPin = 0; // Sets the pin of your variable
int switchState = 0; // Sets the inital value of the switch
const int switchPin2 = 0;
int switchState2 = 0;
pinMode(switchPin, INPUT); // Sets switchPin as an input
pinMode(switchPin2, INPUT); // Sets switchPin as an input
switchState = digitalRead(switchPin); // Outlines what the variable 'switchState' is.
switchState2 = digitalRead(switchPin2);
if (switchState == HIGH) {
CODEsequence();
CODEsequence2();
CODEsequence2();
} else if (switchState == LOW) {
CODEsequence();
CODEsequence();
CODEsequence2();
void CODEsequence(){
Insert the code you want in this sequence, for example:
digitalWrite(ledPin, HIGH);
delay(2000)
digitalWrite(ledPin, LOW);
delay(2000)
void CODEsequence2(){
while (digitalRead(switchState2) == HIGH) { // The code will only run whilst this statement is true.
//Insert the code you want in this sequence.
Welcome to the forum!
Thank you for your contribution.
it would be more valuable if you formatted the code with tags, as defined by the forum guidelines.
Isn't it enough to just provide a function CODEsequence2 for this?
Why you need so much unnecessary code?
This is a great example to follow up with a tutorial on non-blocking fide methods
Or not.
Maybe you meant switchPin, or switchPin2, but those are both zero and that is not a good place for a switch on some Arduino boards.
When you publish a demo, take a few minutes to test it first.
a7
