An Issue with interrupts
Hey guys. I'm a having a problem with my project I have a pair of buttons connected to my inputs, using a 33uF capacitor to debounce the inputs. Using a multimeter I've determined that the hardware that I have created is functioning fine.
The issue I'm having is that the two interrupts appear to trigger each other. I've done extensive research and I can't find an issue. Could someone have a look at my code and see if this issue is coming from something else?
/**Dog Trial Timing software                    **/
/**Write by Hamish Bassett                      **/
/**All software written is believed to be        */
/**origininal. If you believe that your software**/
/**has been copied unfairly contact the author  **/
/**at deaths.swordsman@gmail.com                **/
/**the purpose of this program is to take events**/
/**from the outside world and process them      **/
/**as interupts, using the time to record the   **/
/**events (dogs intersecting an external sensor)**/
/**and return the time that the dog was in the  **/
/**course for the purpose of timing evnents     **/
/**at dog club meets. It is then designed to    **/
/** take the information on times collected and **/
/** send it back to a base station by use of a  **/
/** third party Wi-Fi shield.                   **/
/** This software was written with the platform **/
/** of the Arduino Uno in mind, the details for **/
/** the platform can be found at the            **/
/** manufacturers website URL is                **/
/** http://www.arduino.cc/                      **/
/** The software was written using the IDE for  **/
/** the Arduino Uno found at                    **/
/** http://arduino.cc/en/Main/Software          **/
/** all non standard C/C++ files are under the  **/
/** GNU open source licence and are used as     **/
/** distributed with the above IDE              **/
//pin abstrations
	const int interruptPinDigital2 = 0; //use an abstration to make the code easier to read
	const int interruptPinDigital3 = 1; //an abstraction to make the code easier to read.
	const int LEDPin = 13;
	const int OutputLED1 = 8;
	const int OutputLED2 = 9;
	//all inputs must be volatile type as they can change independant of program.
	volatile int state1= HIGH;
	volatile int state2= HIGH;
	volatile int Interrupt1_Flag=LOW;
	volatile int Interrupt2_Flag=LOW;
	#define TESTING 1	//TESTING is a variable that =1 if the project is testing using a development board (in house only)
void setup () //the inbuilt function to set up the output values of the pins.
		//pin configurations; Unnamed pins are unused and declared in preparation for internal pull up resistor to be turned on
		pinMode (0, INPUT);	pinMode (1, INPUT);
		pinMode (4, INPUT); pinMode (5, INPUT);
		pinMode (6, OUTPUT); pinMode (7, INPUT);
		pinMode (OutputLED1, OUTPUT); pinMode (OutputLED2, OUTPUT);
		pinMode (10, INPUT); pinMode (11, INPUT);
		pinMode(12, INPUT);
		pinMode (LEDPin, OUTPUT); //make pin 13 as an output pin
		//pin high settings turn on internal pull up resistors for unused pins
		digitalWrite (0, HIGH); digitalWrite (1, HIGH);
		/*digitalWrite (3, HIGH);*/ digitalWrite (4, HIGH);
		digitalWrite (5, HIGH); digitalWrite (6, HIGH);
		digitalWrite (7, HIGH); digitalWrite (8, HIGH);
		digitalWrite (9, HIGH); digitalWrite (10, HIGH);
		digitalWrite (11, HIGH); digitalWrite(12, HIGH);
		//pin interrupt associations
		attachInterrupt( interruptPinDigital2, DataRetrieval1, RISING); //associate funtion DataRetrieval with Pin 2 changing state.
		attachInterrupt( interruptPinDigital3, DataRetrieval2, RISING); //associate funtion DataRetrieval2 with Pin 3 changing on the rising edge
//		Interrupt();  //Ensure interrupt on  ************************ Causes an Error
		Serial.println("Dog Trial Starter");
	//Arduino equivalent to main.
void loop ()
		#if TESTING
		digitalWrite(OutputLED1, state1);
		digitalWrite(OutputLED2, state2);
		if (Interrupt1_Flag)
			Serial.println("Interrupt 1 Flag tripped");
			Serial.println("");
			Serial.println("Interrupt 2 Flag tripped");
		#endif
		#if !TESTING
		#endif
	//prototype
	#if TESTING
void DataRetrieval1 ()
		//Serial.println("DataRetrieval1");
		//state1=!state1;
		state1 = HIGH;
		state2 = LOW;
		Interrupt1_Flag=HIGH;
void DataRetrieval2 ()
		//Serial.println("DataRetrieval2");
		//state2=!state2;
		state1 = LOW;
		state2 = HIGH;
		Interrupt2_Flag=HIGH;
	#endif
	#if !TESTING
void Sensor ( /*inputs, I have no idea atm*/)
		//The progam must modify a global counter and test to see if it is the correct value.
		//If it's the incorrect value send a fault through the wifi
		//if not then send the time to the wifi unit
		//then change the value of the global counter
	#endif
Look closely:
Without reviewing the code first, I would really question the use of a 33ufd cap wired to the interrupt pins. Such a large value cap will cause a significant slow rise time and leave the signal inside a unstable voltage zone for much too long. If have never seen a debounce filter that used such a large value.
Lefty
@Nick Gammon: Thanks for pointing that out. But that doesn't solve be basic problem that I have.
Yes it does:
"Appear to" is the operative word. Your print is telling you the wrong thing.
First check your Input is changing state or not through this code
//##################### TEST INPUT PIN2 #########################
  pinMode(2, INPUT);
  int sensorValue = digitalRead(2);
  Serial.println(sensorValue, DEC);
//##################### TEST INPUT PIN3 #########################
  pinMode(3, INPUT);
  int sensorValue = digitalRead(3);
can you plot the debounce time with counts ..
Perhaps you should put the buttons back on the shirt, and get some switches.
