An LED bar graph tachometer
Just another update. I will get this finished some day...
I want this to be a "stand alone" project so I started fooling with ATtiny 85's. Thanks to the kind and patient folks here I've made some progress on that front.
I believe I may be able to run this project with an ATtiny 85. I found this code which runs well on it:
void setup() {                     //nothing to do in setup
byte t = 0;                         //used for looping between LED's in a knight rider kind of fashion
  for (t = 0; t < 10; t++) {
    charliePlex(t);               //switch on LED number T
    delay(75);                     // Wait a bit
  for (t = 9; t >= 0; t--) { // Reverse the run
    charliePlex(t);                // switch on LED number T
    delay(60);                      // delay a bit
  charliePlex(10);               //switch off all LEDs I only had 9, so if you try to switch on any
                                         //bigger number, they would all be off.
  delay(500);                      //big delay before we do it all over again
void charliePlex(byte i) {   // This function switches on one of the LED's. Due to the way I
                                        // laid out my circuit, the pins are not exactly in a logical order,
                                        // but if you understand the concept, it's easy to tune it for your circuit.
  for (int t = 0; t < 4; t++) pinMode(t, INPUT); // I used IO ports 0-4. the ATTINY85 only has 5
        //(or 6 if you sacrifice reset) GPIO's. This loop will switch
        // off all the LED's, because it sets the IO ports to input
        // (high impedance) mode.
  switch (i) {                                       //decide which LED we want to switch on
    case 0: charlieSwitch(2, 0);            //The first LED is wired from Pin 2 to Pin 0
    case 1: charlieSwitch(0, 2);            // the second LED is the reverse of the LED above
    case 2: charlieSwitch(1, 0);
    case 3: charlieSwitch(0, 1);
    case 4: charlieSwitch(1, 2);
    case 5: charlieSwitch(2, 1);
    case 6: charlieSwitch(3, 2);
    case 7: charlieSwitch(2, 3);
    case 8: charlieSwitch(3, 1);
void charlieSwitch(byte pin1, byte pin2) {            //This function merely sets the ports as output,
        // and drives the first one HIGH and the Second one LOW
     pinMode(pin1, OUTPUT);
     pinMode(pin2, OUTPUT);
     digitalWrite(pin1, HIGH);
     digitalWrite(pin2, LOW);
It uses 4 pins to charlieplex 9 LED's leaving 1 pin for input. I'm hoping I can use the last pin for input from the HE sensor but I was wondering if I may need an external clock like a crystal to get it working. It's not going to be a high precision instrument so maybe the chip alone will do it?
Any input would be most welcome!
