Using the internal analog 1.1 VDC A/D reference does not compute?
I am using a temperature sensor LM34DZ as an input to an Arduino analog input.
The "default" internal voltage ref of ~ 5 vdc is being used.
The LM34DZ outputs a voltage equal to 10mv/deg F.
The analog voltage input reads 0.7952 volts @ 10mv/F = 79.52F
The analog count is 159 out of 1024 steps or 0-1023 (10 bit A/D)
159/1023 = .155425219941 X 5000 (mv) = 777.126099705 / 10 mv/F = 77.71 F
This calculation both on the front end voltage and the A/D count is close.
Notes: The exact voltage ref (default) is not exactly 5 VDC but a number close to 5 VDC eg 5.06982.
This gives the calculation 78.77F. vs 79.52F using a 50,000 count voltmeter.
This default ref voltage varies between chip to chip.
The accuracy of the "cheaper" LM34DZ is +-2F
I decided to use the internal A/D 1.1 VDC Voltage ref by using the new command
analogReference(INTERNAL);
The AREF on pin 21 changed from 5VDC to ~ 1.0729 VDC.
The count changed from 159 to 252 with the same input voltage from the LM34DZ.
What does this count of 252 represent?
Note: I am using rev 14 and my various chips are 168P/328P with approximately the same results.
Note: The AREF is not connected to any external voltage source.
:o :o :o
