analog changing duty ratio and frequency in PWM mode
I have a problem in designing a PWM programme that required me to analog changing the duty ratio and frequency.
I want to set the frequency to become <1.5 kHz, 1.5 kHz, 2kHz and 3kHz
and duty ratio of 0, 20%, 40%, 50%, 60%, 80% and 100%.
right now i have done the pwm coding of:
int sensorPin = A0; // select the input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
val01=sensorValue/4
analogWrite(val01); //490Hz
delay(10);
but that is when the frequency is stated.
my question is;
  1. how can I set the frequency using anolog 4 analog button?
  2. what should I put in the previous coding for that desired frequency?
hopefully you can help me =(
faisalirshad: 1) how can I set the frequency using anolog 4 analog button?
I don't know what this means. If you want to select between four possible values, one option is to use a rotary switch to select between different resistance paths through a voltage divider so the Arduino analogue input see four different voltages. Another is to provide four momentary switches each connected to an input; when a switch is pressed, change to the corresponding frequency. In that case it would be helpful to show the current frequency, for example by associating an LED with each switch.
[u]Another is to provide four momentary switches each connected to an input; when a switch is pressed, change to the corresponding frequency. In that case it would be helpful to show the current frequency, for example by associating an LED with each switch.[/u] [/quote]
this is exactly what i want! so, how to programme it in such a way?? I mean, coding for that? right now I confuse how to put coding of that inside the previous coding.
Your exact code depends on the hardware you have. Basically you do an analogue read of the pin and use the map function to reduce it to a value between 0 and 3. Then you use a switch statement on this value to set the appropriator registers on the PWM counting chain. For changing the frequency then see:- http://www.arduino.cc/playground/Code/PwmFrequency and http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM
