analog connections to arduino due
This is getting silly. I cannot come up with the right search terms to discover:
What do I need to get physical/electrical access to the analog sensors on the Arduino due.
By that I mean some hardware to plug in to the board so I can connect the wires from the sensors. Part numbers, pictures, schematics. Please post a link.
Look at the Graynomad pinout diagram:
https://forum.arduino.cc/index.php?topic=132130.0
Sometimes I'm confused as well in search.
bkelly:
What analog sensors on the Due? I don't see any information about any sensors on the board.
Arduino Due
Did you mean to ask how to connect external analog sensors to the analog inputs on the Due?
If so, the same way you would on any other Arduino. Use the analog input pins. As far as any particular analog sensor and interfacing it, it depends on the sensor. What kind of output does it have? You can only give the Arduino a voltage from ground to Vcc. In the case of the Due, 0 to 3.3V.
Then you need to set up those chosen pins as analog inputs.
polymorph:
Arduino Due
You are correct, the analog inputs on the board. The thread referenced in an earlier post is wonderful.
Thank you.
Oh man! I just answered your question in the thread you JUST cross-posted in this very sub-forum!! Why did you do that? I'ma gonna go delete my answer now.
Now that I have mounted the Ethernet shield on the Arduino Due, there is a problem.
Analog inputs A6 and A7 are blocked by the shield. And it looks like getting a connect on for A8 and A9 may be a bit difficult. I am pretty sure I am not the first to observe this.
How do I get to those pins?
ChrisTenone:
And I cannot find a post I thought I made and it might be the one you mentioned. I did do a search and could not find it.
My apologies for any cross post.
If you want to access all pins when there is a shield above the DUE, this Mega/Due shield that you can find at crossroadsfencing.com may be handy:
bkelly:
Ok, well my suggestion was to solder a couple wires onto the bottom of the board. I did this with a mini, where the i2c pins are in the middle of the board.
ard_newbie:
That device looks quite cool, just what I need. But the site:
http://crossroadsfencing.com/
Appears to be a fencing as in those long skinny swords and it closed down in August.
bkelly:
On that page, see where it says "custom electronics will continue" a few lines down? That text is a link, click it, and you'll see that board.
What Ethernet shield, post link to data/specs please?
Thanks... Tom... :slight_smile:
TomGeorge:
The Ethernet shield is part no. A000024, description is Ethernet Shield 2 w/o POE
Hmmm, I think that means with out Power Over Ethernet. Maybe using a shield with POE would eliminate the need for a power supply. I will stay with what I have but once built I can try a new shield and see if that works. There will be ten sensors each of which has three leads, common, power, and voltage out. That means they each draw some amount of power. That will be for later.
Is it this shield?
How does it block A6 and A7, the board edge is cut away so it shouldn't stop you plugging into the DUE pins?
I cannot see the attachment as I write this but will continue.
On the left side pin A6 is physically obscured A7 is sufficiently close to preclude mounting a connector.
I am planning on ten analog inputs and do not want to just push wires in connector holes in the hope that they will stay there. The Mega Shield with the screw downs is the answer.
However, there is a problem. I did not look far enough down that page to find all the boards and ordered one elsewhere. I did not notice that it does not have a six pin connector for the six pins in the middle of the DUE. When the Ethernet is mounted on top of it, the Ethernet stops working. The crossroads device appears to have that connector.
So I sent an email to the crossroads fencing, they have responded and am ordering their shield.
Edit 14 Jan 2019
I now have the Screw Shield in hand, have plugged it into the Arduino and plugged the Ethernet shield into that shield. The example program I found reads the analog inputs and provides them as a served web page. That was compiled and downloaded. It would not run with the original mega shield but does run with the one from Crossroads Fencing.
I use a Chrome browser on Windows 10 and it does display all the analog inputs. No sensors yet.
Now, I have screw down connection where all the sensor wires can be landed and expected to stay where put. Next step is to attach some sensors and see what I get.
Just for info, the first screw shield does not have a manufacturer name on it, maybe they're not so proud of it. Just looked it up, it is from CNEWTEX. It does have what looks like a part number: BTE16-06 It does not have a matching socket for the six pins sticking up from the center of the DUE board. If you want to use a screw shield and plug an Ethernet shield on top, use the Crossroads Fencing device.
Its kind of expensive, but it does have 48 screw down terminals. Each of those have at least two moving parts that must be assembled so the cost is justified.
