Analog current draw
Umm im pretty sure putting the half an amp into the analog pin is probably what killed it. In the future for testing pins, try going from 5v to 1 leg of a pot, middle leg to the analog, and last leg to ground. It should make a voltage divider that will let you show the full range, 0-1023 of the analog pin when you turn the pot, and it won't kill the pin, (might damage it if you put the pot @ 0 and have the full current going into the pin though, should probably put identical resistors in series with the gnd and 5v legs. I use ruggeduino now because i know how often i break stuff)
