analog differential pressure sensor
I picked up a couple of these from work. They were samples, I think. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=356-1040-ND
They are pretty pricey, but the price was right for me, so I rescued them from the dumpster. I wrote a short program to interface. It's pretty simple, but I can see lots of uses for something like this. If anyone else is able to score one of these for cheap, try it out. Could probably use for airspeed indicator with pitot tube, water level indicator, airflow indicator in HVAC system, etc.
 * Pressure Sensor GA 200-5WD
 * http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=356-1040-ND
 * by Chad Richardson
 * Uses pin 14 as supply voltage (+5V) and pin 15 for ground
 * Pin 16 is the output from the sensor--range is 0.25VDC to 4.0VDC (0 - 5 inches of water)
 * the value obtained by analogRead().
int VPin = 14;    // select the supply voltage pin
int GPin = 15;   // select the pin for Ground
int val=0;
  pinMode(VPin, OUTPUT);      // declare the VPin as an OUTPUT
  digitalWrite(VPin, HIGH);   // set VPin to HIGH
  pinMode(GPin, OUTPUT);      // declare GPin as as an OUTPUT
  digitalWrite(GPin, LOW);    // set GPin to LOW
  Serial.begin(57600);        // use serial communication to output to computer
  val = analogRead(2);        // read the value from the sensor
  val = map(val, 48, 818, 0, 5);  //Convert 10 bit reading to inches of water
  Serial.println(val);        // print the value to PC via serial and perform carriage return
  delay(100);                 // stop the program for some time
The spec sheet says that they are available in 0-5, 0-10, 0-15 in H2O and 0-1 psi. Electronic water manometer for low pressure airflow measurements. Thanks for the pointer.
A sweet little application. I see a niche for this type of device in the assessment of the troublesome FAP filters which are becoming standard on Diesel automobile exaust pipes.
These are very expensive to replace, cause a host of management false alarms, the garage response is to change the unit.
It is simply a matter of teeing into the two existing small bore rubber pipes . A running record of back pressure etc. will avoid blockage, consequential damage and very expensive analyser sessions. Now I must find a source of differential p.t. of the right range at the right price. Has anybody out there some ideas?
