I am trying to read a voltage(below 1 volt) on A0, using the analog read/serial sketch, but the readout is nowhere what shows on the LCD of my device... and I know too little to understand the problem! I have a delay in the sketch, have changed that (incr and decr), thinking the problem is latency. No better. The readouts are from zero V up to numbers that have no relationship to reality whatsoever. I can read the voltage out with a standard V/Ohm meter, and as I said there is a LCD on the device (Radio Shack Sun and Sky Monitoring Station). Any ideas?
thanks
Don't see code, don't see a schematic.
Any ideas?
yep, have you read this tutorial - http://arduino.cc/en/Tutorial/AnalogInput -
but it could be also some other problem, so please follow AWOL's advice and post all information you have.
The more information in the question the better answer
If you are reading a rapidly varying voltage then analogRead() gives a snapshot of the voltage taken over a few microseconds or so.
A digital multimeter measures a time-averaged value over a substantial fraction of a second. A voltage with a lot of noise will thus read
as a steady value on a DMM and apparently highly random using analogRead().
Perhaps you need to bandwidth limit the signal of interest with a low-pass filter?
Got no code, other than the analog in / serial sketch I mentioned. Got no schematic, other than two contact points out of the device marked + and -...
Could I program a way to take several snapshots of the voltage reading and average them? I thought of this, but at this point all the readings seem to be unrelated to one another, and the voltage should be a steady reading out, as it is the light reading from a diode, used as a light sensor.
As to the advice about limiting the bandwith of the signal, I will look into that. thank you very much.
My son gave me a MEGA for Christmas... gonna try that, too.
Thanks everyone, and merry christmas/happy holidays!
jim
Well there's the obvious issue - what light is falling on the diode? Fluorescent? compact fluorescent? Or is it really a constant
light source such as the sun or tungsten filament bulb?
Got no schematic, other than two contact points out of the device marked + and -…
Got a link to the ‘device’ that has + and - contact points?
Lefty
You can set the analog reference to 1.1 Volt internal to make the ADC more sensitive..
I tried setting the ref voltage, but didn't understand how to use the code. I can read a 1.5V battery cleanly, but the readings I need to make are less than 1 V, and I guess the resolution is the problem. Perhaps I can amplify the output with a buffer? I sure wish I knew what I was doing :~
Hi eatabean,
We'd love to help, but without a copy of the sketch and a description of your wiring, we're at a loss too!
Copy and paste the sketch in a reply and talk us through the wiring. The project you describe seems pretty straight forward and shouldn't need anything fancy to make work.
Pat.
The analog input will have a voltage input and will return a result between 0 and 1023.
So if your input voltage is 1 volt and your reference voltage is 5V, the result of the analog input read
operation would be a number around 200.
If you try reading the voltage of a 1.5V battery, your number in the arduino would be about 300.
Is that what you get when you try measuring the voltage of a battery ?
