analog input as output?
I am a total microcontroller beginner and I have a project that requires a few more outputs then provided 14 on the duemilanove.
Is it possible to use the analog in pins to switch a led?
Yes. Just continue incrementing the pin number.
That means when you use analogue pin 0 as a digital output refer to it as Pin 14, with A1 as Pin 15 and so on.
Thanks you two, that's all I needed before I placed my order. I'm sure I'll be back to the forum soon.
I appreciate the help, had fun!
