Analog Input gives the same value
Hello Everyone,
I am new to Arduino. This is the first time I am trying something with Arduino.
I am trying to do a 7 band spectrum analyser with electret mic and msgeq7 with Arduino UNO. I first tried connecting the ledstrip and was so excited when it worked (although its very simple, lol) but when I connect the mic and msgeq7 to Arduino and read analog signal, it gives same values in silence and when there is music playing as well. Even when I read analog signal from a different pin which is not connected to anything, it still reads the same values. So, I am assuming that there is some problem in the circuit or something.
I have attached the schematic (I am not using the clock module, pin 8 on msgeq7 is not attached to anything. I am using only 1 msgeq7 as its only 7 band and not 14 band analyser. For audio input, I am using electret mic, the rest is all the same as shown in the attached diagram).
This is the output from serial monitor:
237
237
237
237
237
237
237
237
237
237
236
237
237
236
236
237
236
236
237
237
236
237
237
236
237
237
237
237
237
237
237
237
237
237
237
237
236
237
237
237
237
237
237
237
237
237
237
238
237
237
238
237
237
237
238
238
238
239
238
238
239
238
239
239
238
239
238
238
238
238
238
238
238
238
237
237
238
237
237
237
237
237
237
237
237
237
237
236
237
237
236
238
237
237
237
237
237
237
238
238
238
238
238
238
239
240
239
240
240
240
240
241
241
241
244
241
241
241
241
241
241
242
241
241
242
242
243
243
243
243
244
244
245
246
247
247
248
249
249
251
253
253
254
256
257
258
259
260
2616
23
265
265
267
269
271
272
273
273
274
275
275
276
277
277
277
278
278
278
279
280
279
279
279
278
278
279
277
277
278
277
276
276
276
275
276
276
274
274
274
273
272
272
271
270
270
269
269
269
269
268
269
269
268
268
268
267
268
2686
27
267
267
267
266
267
267
266
266
267
266
267
267
267
267
268
267
267
268
267
267
267
266
266
266
266
265
265
266
265
265
265
265
265
265
265
265
265
265
264
264
264
263
263
264
263
263
264
263
263
263
263
263
263
263
262
263
263
2
26
263
263
263
263
263
262
262
263
262
262
262
262
261
261
261
260
260
260
260
258
258
258
258
258
258
258
258
258
258
258
258
258
258
258
257
258
258
258
258
258
258
258
258
Could you guys please help me out!
Thank you
Schematic Diagram.pdf (862 KB)
First of all the LED strip needs to be powered from an external power supply.
Re-posted as .jpg with img tags
What are you running for a sketch?
Serial.println(analogRead(A1));
I am just checking if the circuit is working fine. If its working fine, I will then connect the LED strip.
