One of my five analog input pins shows 5 volts, or 100% input value no matter where the potentiometer is set; other than 5% or less of potentiometer position. 10k pot, once I turn it up to about 5% it just maxes the value (255). I’ve tried different pots too. The four other inputs work fine. I can move the pin to another A pin in the program and it works, but I can’t figure out why this particular pin is behaving this way.
A1 is the faulty pin. I can move it to A7 and it’s happy with the rest of them. This is also being prototyped on a breadboard, nothing soldered yet.
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <ArducamSSD1306.h>
//DEFINE I/O TAGS AND PINS
const int trigPin=PIN5;
const int echoPin=PIN6;
const int stopLight=PIN2;
const int driveLight_1=PIN3;
const int driveLight_2=PIN4;
const int DL_1_Low_Pot=A0;
const int DL_1_High_Pot=PIN_A1;
const int DL_2_Low_Pot=A2;
const int DL_2_High_Pot=A3;
const int stopLight_Pot=A6;
//SET INTERNAL TAGS AND VALUES
float duration, distance;
int stopSetPoint = 0; //stop light on less than this distance
int driveLight_2_LOW = 0; //drive light 2 on greater than this distance
int driveLight_2_HIGH = 0; //drive light 2 on less than this distance
int driveLight_1_LOW = 0; //drive light 1 on greater than this distance
int driveLight_1_HIGH = 0; //drive light 1 on less than this distance
int driveLight_1_lowValue = 0; //placeholder value for analog input
int driveLight_1_highValue = 0; //placeholder value for analog input
int driveLight_2_lowValue = 0; //placeholder value for analog input
int driveLight_2_highValue = 0; //placeholder value for analog input
int stopLight_Value = 0; //placeholder value for analog input
//LCD SETUP
#define OLED_RESET 15 // Pin 15 -RESET digital signal
ArducamSSD1306 display(OLED_RESET); // FOR I2C
//FUNTIONS SETUP
void callUltraSonic(int num);
void callStopLight(int num);
void calldriveLight_1(int num);
void calldriveLight_2(int num);
void call_analogValueScans(int num);
void call_OLED_Print(int num);
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(stopLight, OUTPUT);
pinMode(driveLight_1, OUTPUT);
pinMode(driveLight_2, OUTPUT);
// initialize OLED with I2C addr 0x3C
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
Wire.begin();
callUltraSonic(1);
callStopLight(2);
calldriveLight_1(3);
calldriveLight_2(4);
call_analogValueScans(5);
call_OLED_Print(6);
void callUltraSonic(int num) {
// Write a pulse to the HC-SR04 Trigger Pin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Measure the response from the HC-SR04 Echo Pin
duration = pulseIn(echoPin, HIGH);
// Determine distance from duration
// Use 343 metres per second as speed of sound
distance = (duration / 2) * 0.0343;
// Serial Print "out of range"
Serial.print("Distance = ");
if (distance >= 400 || distance <= 2){
Serial.println("Out of range");
// Serial Print "distance in cm"
else {
Serial.print(distance);
Serial.println(" cm");
delay(100);
void callStopLight(int num) {
//Serial Print "STOP"
//Turn stop light on HIGH if less than setpoint
//Else turn stop light off LOW
if (distance < stopSetPoint){
digitalWrite(stopLight, HIGH);
Serial.print(" STOP ");
else {
digitalWrite(stopLight, LOW);
void calldriveLight_1(int num){
if (distance > driveLight_1_LOW && distance < driveLight_1_HIGH) {
digitalWrite(driveLight_1, HIGH);
else {
digitalWrite(driveLight_1, LOW);
void calldriveLight_2(int num){
if (distance > driveLight_2_LOW && distance < driveLight_2_HIGH) {
digitalWrite(driveLight_2, HIGH);
else {
digitalWrite(driveLight_2, LOW);
void call_analogValueScans(int num){
//DRIVE LIGHT 1 LOW VALUE FROM POT
driveLight_1_lowValue = analogRead(DL_1_Low_Pot);
driveLight_1_LOW = map(driveLight_1_lowValue, 0, 1023, 0, 255);
Serial.print("DL1Low = ");
Serial.print(driveLight_1_LOW);
//DRIVE LIGHT 1 HIGH VALUE FROM POT
driveLight_1_highValue = analogRead(DL_1_High_Pot);
driveLight_1_HIGH = map(driveLight_1_highValue, 0, 1023, 0, 255);
Serial.print("DL1High = ");
Serial.print(driveLight_1_HIGH);
//DRIVE LIGHT 2 LOW VALUE FROM POT
driveLight_2_lowValue = analogRead(DL_2_Low_Pot);
driveLight_2_LOW = map(driveLight_2_lowValue, 0, 1023, 0, 255);
Serial.print("DL2Low = ");
Serial.print(driveLight_2_LOW);
//DRIVE LIGHT 2 HIGH VALUE FROM POT
driveLight_2_highValue = analogRead(DL_2_High_Pot);
driveLight_2_HIGH = map(driveLight_2_highValue, 0, 1023, 0, 255);
Serial.print("DL2High = ");
Serial.print(driveLight_2_HIGH);
//STOP LIGHT VALUE FROM POT
stopLight_Value = analogRead(stopLight_Pot);
stopSetPoint = map(stopLight_Value, 0, 1023, 0, 255);
Serial.print("StopLight = ");
Serial.print(stopSetPoint);
//OLED DISPLAY
void call_OLED_Print(int num){
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
//Drive Light 1 Low/High
display.setCursor(0,3);
display.print("DL1L = ");
display.print(driveLight_1_LOW);
display.setCursor(67,3);
display.print("DL1H = ");
display.print(driveLight_1_HIGH);
//Drive Light 2 Low/High
display.setCursor(0,20);
display.print("DL2L = ");
display.print(driveLight_2_LOW);
display.setCursor(67,20);
display.print("DL2H = ");
display.print(driveLight_2_HIGH);
//Stop Setpoint
display.setCursor(0,40);
display.print("STOP = ");
display.print(stopSetPoint);
display.display();
//Live Sensor Read
display.setCursor(0,50);
display.print("LIVE = ");
display.print(distance);
display.display();
