Analog input pins as DOs problem.
Hello all, I have an Arduino Uno R3 connected to a 4 digit, 7 segment display (the part number is not on the display but it has 6 pins in a row at the top back and 6 on the bottom if that helps). Anyhow, this display works fine when connected to 12 Uno DI pins. However, I thought it would be useful to connect the top 6 display pins to the Uno AI pins (using A0 to A5) to shorten up and simplify the wiring when the display is mounted on a breadboard shield.
So, I began switching the top display pin wires to the Uno AI pins one at a time starting with a connection going to A5 - it worked fine. Then went to A4, A3 and A2 with the next connections and all OK. The problem started with connecting to A1 - the display digit segment controlled by that connection was dead and same issue occurred with a similar connection to A0. I have tried the pinMode(A1, OUTPUT); statement but was of no help.
I guess the question is, is there something different about the A0 and A1 pins? I can't think of anything else to try and would appreciate any assistance.
TIA!
There should be no difference. Please post a schematic. Also your code, in code tags please...
Sorry, don't have a schematic but the code follows. As noted, the code works, (displaying time of day, temperature and humidity and, with an IR control to adjust the time); problem arises when switching display pin connections from digital pins to analogs. I wonder if the problem is in the SevSeg.h library??
/*Time of day clock showing hours & minutes plus temperature & humidity on 4 digit 7 segment display
   Uses a no-block timer "millisDelay" so display can be continually refreshed (required for non-flicker o/p)
   Uses IR remote reader to set current hours and minutes
  Requires the following Arduino libraries (for temperature & humidity sensor):
  - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
  - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include "DHT.h" //Humid & Temp sensor ("DHT")
#include <millisDelay.h> //Non-blocking delay library - for 2 second clock increment trigger
#include "SevSeg.h" //7 segment display //To display time, temperature & humidity
#include "IRremote.h" //IR receiver //For setting correct hours & minutes
int receiver = A0; // Signal Pin of IR receiver to Arduino Analog Pin A0
IRrecv irrecv(receiver);    // create instance of 'irrecv'
decode_results results;     // create instance of 'decode_results'
millisDelay clockDelay; //Initiate a delay object
SevSeg sevseg; //Initiate a seven segment controller object
#define DHTPIN A1     // Pin connected to the DHT sensor (use an AI as a DI as the display uses all the DI pins)
#define DHTTYPE DHT11   // DHT 11 type sensor
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
int hours;
int minutes;
int seconds;
int displaytime;
int countr;
float t;
float h;
  Serial.begin(9600); // Initialize the serial printer (for debugging)
  dht.begin(); // Initialize the DHT sensor
  clockDelay.start(1000);  // start a 1 sec delay (1,000 msec)
  hours = 1; minutes = 0; seconds = 0; //Start with this time
  countr = 0; //If countr = 0, display time; if = 1, display temperature; if = 2, display humidity (& switch at 1 second intevals)
  byte numDigits = 4; //Set pin assignments for display
  /*byte digitPins[] = {2, 3, 4, 5}; //Original example program arrangement
    byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13};
  byte digitPins[] = {2, 5, 6, 13}; //Arrangement for connectors to go straight from display pins to Arduino w/o criss-crossing
  byte segmentPins[] = {3, 7, 11, 9, 8, 4, 12, 10};
  byte digitPins[] = {A5, A2, A1, 13}; //Arrangement for top 6 display pins to connect to Arduino AI pins (to simplify & shorten wiring)
  byte segmentPins[] = {A4, 7, 11, 9, 8, A3, 12, 10};
  // All AIs work except A1 (and A0).
  // variable below indicates that 4 resistors were placed on the digit pins.
  // set variable to 1 if you want to use 8 resistors on the segment pins.
  bool resistorsOnSegments = 0;
  sevseg.begin(COMMON_CATHODE, numDigits, digitPins, segmentPins, resistorsOnSegments); //Initialize the display
  sevseg.setBrightness(90); //Doesn't seem to change brightness much
  irrecv.enableIRIn(); // Initialize the IR receiver
  // Check if delay has timed out - if so, increment clock by 2 seconds & read temperature & humidity
  if (clockDelay.justFinished()) { // Only returns TRUE once.
    clockDelay.start(2000);  // Restart delay - 2,000 ms
    seconds = seconds + 2;
    if (seconds == 60) {
      seconds = 0;  //Adjust minutes & hours accordingly
      minutes = minutes + 1;
    if (minutes == 60) {
      minutes = 0;
      hours = hours + 1;
    if (hours > 12) {
      hours = 1;
    displaytime = hours * 100 + minutes; //Calculate time number to display
    countr = countr + 1; //To display next value
    if (countr == 3) {
      countr = 0; //Ranges from 0 to 2
    if (countr == 1) { // Read temperature - takes about 250 mseconds
      // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
      // Read temperature as Celsius (the default)
      t = dht.readTemperature();
      t = t * 0.96; // Correction factor (as compared to other thermometers)
    if (countr == 2) { //Read humidity
      h = dht.readHumidity();
      h = h * .95; // Humidity correction factor
  if (countr == 0) { //Display time (in hours & minutes)
    sevseg.setNumber(displaytime, 2); // 2nd variable sets decimal point position (0 for RHS digit up to 3 for LHS digit)
    sevseg.refreshDisplay(); // Must run repeatedly & rapidly for persistance of vision effect
  if (countr == 1) { //Display temperature
    sevseg.setNumber(t, 1); // 2nd variable sets decimal point position (0 for RHS digit up to 3 for LHS digit)
  if (countr == 2) { //Display humidity
    sevseg.setNumber(h, 0); // 2nd variable sets decimal point position (0 for RHS digit up to 3 for LHS digit)
  if (irrecv.decode(&results)) { // Have we received an IR signal from remote control?
    if (results.value == 0xFFA857) { //VOL- remote button
      minutes = minutes - 1;
      seconds = 0;
    if (results.value == 0xFF629D) { //VOL+ remote button
      seconds = 0;
    if (results.value == 0xFF22DD) { // Fast backward
      hours = hours - 1;
    if (results.value == 0xFFC23D) { // Fast forward
      hours = hours + 1;
    irrecv.resume(); // receive the next IR value
Thanks for any suggestions!
The sketch is using A0 for an infrared receiver and A1 for the DHT pin. You can't also use them for the disply.
johnwasser:
Thanks John, I just noticed that a minute ago. Forgot to change the pin assignments for the IR and DHT. :confused:
Doh!
If you had a schematic, you would have noticed. :slight_smile:
aarg:
Workin' on it :slight_smile:
Do you have a recommendation for a schematic editor/simulator?
BTW, have just migrated from PicAxe to Arduino. Pretty nice so far but I do miss the debug capability.
