Analog input protection using a resistor
Hello
I've been trying to find a way to protect my analog input pins (for my Leonardo and Pro micro). I'm basically using them to read an amplified piezo sensor output. The output is amplified because I'm using it to measure very low signal (heartbeats). The normal level of the sensor's output doesn't exceed 5V when I'm measuring heartbeats or chest movement, yet when the sensor is moved rapidly or lifted, I can expect a 5v+ voltage. I know that Arduino has an internal protection circuit, will that be enough to combat those sudden movements?
If not, I've read so many posts on this topic including this one:
http://www.thebox.myzen.co.uk/Tutorial/Protection.html
If I wanted to add a series resistor by itself as a protection will it be okay? and also, my signal is already small, wouldn't adding a resistor attenuate it even more?
Most circuits seem to have a capacitor, my signal is DC shifted upward (to avoid -ve voltage), wouldn't the capacitor remove that offset?
Finally, if I wanted to use the diode clamping diodes, which diodes should I use (i.e 1n4148 or 1n4002)?
Thank you
