I'm using the Bluefruit LE Shield with an Arduino Uno to send analog input data over bluetooth using the UART service.
Here is the relevant code loop on the board:
val = analogRead(pin);
// val += 1;
Serial.print(millis());
Serial.print(", ");
Serial.println(val);
Ble.println(val);
// delay(1);
and here is the querying code (python) on my computer:
import time
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.nordic import UARTService
delay = 100 # ms
board_name = 'Bluefruit LE Shield'
ble = BLERadio()
while not ble.connected:
for ad in ble.start_scan(ProvideServicesAdvertisement, timeout=1):
name = ad.complete_name
if name == board_name:
ble.connect(ad)
break
ble.stop_scan()
# assert ble.connected, f"{board_name} not found"
try:
uart = ble.connections[0][UARTService]
except Exception as e:
print(f"UARTService not found in {board_name}")
count = 0
ct = time.time()
encoding = 'utf-8'
while ble.connected:
ba = uart.read()
print(ba)
try:
data = int(ba.decode(encoding))
# if data < 0 or data >= 1024:
# raise ValueError()
print(data, (time.time() - ct), count)
count += 1
except:
pass
time.sleep(delay/1000)
I expect the Arduino to sample at ~4ms per value as it does initially. Here's a table with time (from millis()) on the left and random analog values on the right:
2368, 420
2371, 420
2375, 417
2378, 415
2382, 416
2385, 418
2388, 417
2393, 415
2402, 415
2413, 411
2424, 412
2436, 412
However, when transmitting the data over bluetooth, it exhibits the following pattern:
17435, 331
17438, 327
17442, 314
17530, 300 <-- 100 ms jump
17533, 313
17539, 310
17542, 296
17630, 278 <-- 100 ms jump
17633, 292
17637, 297
17640, 281
Does anyone know how to address this problem, or how to increase the analog pin sampling rate?
Thanks!
