I've created a simple set of Arduino/Processing programs for visualizing the raw values of the analog inputs on the Arduino.
(screencap only shows 2 inputs active).
The Arduino portion of the program is very simple, it just reads in the analog inputs and writes raw values to the serial port as a set of comma separated values. It uses a very simple handshaking method to send the data.
The Processing portion reads in the data from the serial port and graphs it on the screen, tracking the min and max values.
Both pieces of code are hardcoded for 6 analog inputs, as I was using this with a Duemilanove, but it is trivial to change to more/less AIs.
Here's the code for the Arduino:
prints value of each analog input to serial port as comma seperated values:
AI 1, AI 2, AI 3, AI 4, AI 5
d.jurnove 2009
int sensors[6];
if (Serial.available()>0) {
Serial.read(); //discard first byte
for (int i = 0; i < 6; i++) {
sensors[i] = analogRead(i);
Serial.print(sensors[i]);
if (i <5) {
Serial.print(",");
Here's the Processing code:
Plots analog inputs as read in from Arudino
d.jurnove 2009
import processing.serial.*;
Serial myPort;
final int linefeed = 10;
//maximum number of sensors to display
final int maxSensors = 6;
//raw analog input values from controller
int raw[];
int rawMin[];
int rawMax[];
//values scaled to fit screen
float scaledVal[];
float scaledMin[];
float scaledMax[];
float prevScaledVal[];
//min/max values of analog input from controller
final int minAnalogVal = 0;
final int maxAnalogVal = 1024;
//colors used to draw sensor graphs
color colors[];
int xCursor = 0;
//length of each line segment in graph, 1=1 pixel
final int plotLineLength = 1;
PFont myFont;
final int fontSize = 12;
final int drawDelay = 10;
boolean madeContact = false;
//println( Serial.list() );
myPort = new Serial(this, Serial.list()[7], 9600);
myPort.bufferUntil(linefeed);
//initialize raw vars
raw = new int[maxSensors];
rawMin = new int[maxSensors];
for (int i = 0; i<rawMin.length; i++) {
rawMin[i] = 2147483647;
rawMax = new int[maxSensors];
//initialize scaled vars
scaledVal = new float[maxSensors];
scaledMin = new float[maxSensors];
for (int i = 0; i<scaledMin.length; i++) {
scaledMin[i] = 2147483647 ;
scaledMax = new float[maxSensors];
prevScaledVal = new float[maxSensors];
//set colors used for each sensor display
colors = new color[maxSensors];
colors[0] = color(255, 0, 0); //red
colors[1] = color(0, 255, 0); //green
colors[2] = color(0, 0, 255); //blue
colors[3] = color(255, 255, 0); //yellow
colors[4] = color(0, 255, 255); //teal
colors[5] = color(255, 0, 255); //purple
//println(PFont.list());
PFont myFont = createFont(PFont.list()[12], fontSize);
textFont(myFont);
size(800, 600);
background(102);
void draw() {
stroke(102);
fill(102);
//erases text area
rect(0,0,300,170);
if(madeContact==false) {
//start handshake w/controller
myPort.write('\r');
fill(255);
//draw text header
text("Analog Input Monitor v1.0", 2, fontSize);
//draw text output for each sensor
for (int i = 0; i < raw.length; i++) {
fill(colors[i]);
text(" Analog Sensor " + i + ":" , 2, fontSize*(2*(i+1)));
text(" Raw: " + raw[i] + " Min: " + rawMin[i] + " Max: " + rawMax[i], 2, fontSize*(2*(i+1)+1));
//draw each graph line segment
for (int i = 0; i < scaledVal.length; i++) {
stroke(colors[i]);
//current value
line(xCursor, height-prevScaledVal[i], xCursor + plotLineLength, height-scaledVal[i]);
//min value
line(xCursor, height-scaledMin[i], xCursor + plotLineLength, height-scaledMin[i]);
//max value
line(xCursor, height-scaledMax[i], xCursor + plotLineLength, height-scaledMax[i]);
prevScaledVal[i] = scaledVal[i];
xCursor+=plotLineLength;
if (xCursor > width ) {
background(102);
xCursor = 0;
delay(drawDelay);
void serialEvent(Serial myPort) {
madeContact = true;
String rawInput = myPort.readStringUntil(linefeed);
if (rawInput != null) {
rawInput = trim(rawInput);
int sensors[] = int(split(rawInput, ','));
//print("raw: ");
//read in raw sensor values
for (int i=0; i<sensors.length; i++) {
raw[i] = sensors[i];
rawMin[i] = min(rawMin[i], raw[i]);
rawMax[i] = max(rawMax[i], raw[i]);
//print(i + ": " + raw[i] + "\t(" + rawMin[i] + "|" + rawMax[i] +")\t");
println();
//print("scaled: ");
//scale raw sensor values
scaledVal[i] = height * (raw[i] - minAnalogVal) / maxAnalogVal;
scaledMin[i] = height * (rawMin[i] - minAnalogVal) / maxAnalogVal;
scaledMax[i] = height * (rawMax[i] - minAnalogVal) / maxAnalogVal;
//print(i + ": " + scaledVal[i] + "\t(" + scaledMin[i] + "|" + scaledMax[i] +")\t");
//println();
//request more data from controller
myPort.write('\r');
Hope someone finds this useful! I used it to see how my photoresistor sensors reacted while I was building a basic Braitenberg light-averse robot.
