analog input voltage sweep counter.
hi
im trying to count the number of times an analog input goes below (or above) a set voltage, in hopes to count a crank position pulses. i came up with some test code, using a potentiometer to simulate a the change in voltage of the sensor, it works fine except i need it to only add 1 to the counter, rather the constantly count up as long as the voltage is above or below the set voltage, i cant seem to find a way only increment by 1. any help would be great thx
int LED = 13;
int counter = 0;
 pinMode(LED, OUTPUT);
  int sensorValue = analogRead(A2);
  float voltage = sensorValue * (5.0 / 1023.0);
if (voltage > 0.42) digitalWrite(LED, LOW);
if (voltage < 0.42) digitalWrite(LED, HIGH);
if (voltage < 0.42) counter++;
  Serial.println(counter);
You need to remember what the prior voltage was (or if you incremented the counter) and then use that knowledge combined with the current voltage level to decide if you need to increment again or not
Also, voltage = sensorValue * 5.0 / 1024.0
so im amusing there isnt way to delay the next count until the voltage drops ? ive seen code where there is a memory counter to compare to but i dont understand it.
and so i dont need the "float" ?
thx
something like this should do what you want:
int LED = 13;
int counter = 0;
bool counterIncremented = false;
const float threshold = 0.42;
  float voltage = sensorValue * (5.0 / 1024.0);
  if (voltage > threshold) {
    // we are at or below threshold
    if (counterIncremented == false) {
      counter++;
      counterIncremented = true;
[\code]
kdglv:
thx
Look at the StateChangeDetecion example in the IDE to see how to detect when a values becomes LOW or less than a value rather than when it is LOW or below a value. Same for HIGH/higher than
Better still, don't do any floating-point at runtime, but get the compiler to calculate the threshold as ADC counts.
