It does not read in the analog value. I read the examples and tried since hours. I do not find out what am I doing wrong.
I have a Digispark ATTINY85 USB, I try to make a small temperature controller. But first I want to read in the analoge value on pin 0. It always shows 1023 or 1017 instead of the equivalent of 2V in my case which should be around 400 units. I connected the 10k NTC between A0 and +5V and a resistor of 4.7k between A0 and ground. The output does work and the serial to the notebook too which I use as readout.
My code is
Many thanks for your help Franz
/#include "DigiKeyboard.h"
int sensorPin = A0; // select the input pin for the NTC
int sensorValue = 0; // variable to store the value coming from the sensor
// don't need to set anything up to use DigiKeyboard
pinMode(1, OUTPUT); //LED on Oak
// Type out this string letter by letter on the computer (assumes US-style
// keyboard)
DigiKeyboard.println("ColorDisk Temperature is");
// It's better to use DigiKeyboard.delay() over the regular Arduino delay()
// if doing keyboard stuff because it keeps talking to the computer to make
// sure the computer knows the keyboard is alive and connected
DigiKeyboard.delay(1000);
//main loop Heater
digitalWrite(1, HIGH);
// longer off time
digitalWrite(1, LOW);
delay(100);
//main loop measuring NTC Temp
//Measure NTC value
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
DigiKeyboard.println("Analoge ");
DigiKeyboard.println(sensorValue);
