Analog input
Hello, i have a 0-200mV AC signal i want to connect to a input. Is this possible and wich board do you recomend. I want to use this variable input to create a variable output 0-5VDC.
Thanks
What speed is the A/C signal?
How many bits of precision do you need?
To digitise an A/C signal you have to shift the zero level to the mid point of the arduino’s supply. Do this with a pair of resistors, then AC couple your signal into this. This means connecting it through a series capacitor.
As for output you either need an external D/A or use PWM and a filter.
Grumpy_Mike:
This Emma’s connecting it through a seriese capacitor.
some glitch in the typing?
…R
Thanks Robin2, that is my iPad again thinking it knows what I am saying.
Grumpy_Mike: Thanks Robin2, that is my iPad again thinking it knows what I am saying.
I would speak firmly to your IPad. That sort of loose talk could easily get you in trouble :)
...R
