Analog Inputs not working correctly at all!
Hello everyone!
I am trying to read 3 thermistors and spit it out onto a webpage. I am having some problems so decided to check out whats really going on.
I plugged the USB cable into the Arduino+EtherShield and just did (all the way to 5). Output below is with nothing hooked up to the board.
client.print(analogRead(0));
client.print(" - 1
client.print(analogRead(1));
client.print(" - 2
And got this as an output on the webpage:
1023 - 1
1023 - 2
931 - 3
833 - 4
717 - 5
649 - 6
I then wanted to see what happened without anything hooked up to the arduino... just the board itself (no shield) and did this:
   Serial.println(analogRead(0));
   Serial.println(analogRead(1)); (all the way to 5)
And got this for the output with no wires connected (kept floating... ok....):
415
407
369
332
290
304
And this when I hooked up 3 aInputs with everything (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1254096639/3) but the thermistors:
0
0
0
114
179
219
What is happening to the analog inputs with the Ethernet Shield? Is their something I am doing wrong? >:(
So why would the first two analog inputs state 1023 when nothing is connected to them? Does it have to do with the Ethershield?
I never said anything was wrong with the arduino. (Just said the analog inputs weren't working :wink: )
Jut to reiterate what you are seeing is the expected correct behavior from your analogue inputs. They all behave like this. Look up floating inputs.
^Where I purchased it from
Mike: I now know that the floating values are normal.
Following the links on Adafruit's site, I found a link to the schematic. Look at J2 (Far Right Side): http://arduino.cc/en/uploads/Main/arduino-ethernet-shield-05-schematic.pdf
Pins 1 and 2 of J2 which are Analog input 0 and 1 have external Pull-Up resistors on them.
