Analog Inputs reading voltage with nothing plugged in...
First time using the board. tried to measure voltage using the analog inputs. Was not getting the desired result. Opened the serial monitor, when I unplugged the jumpers from the board and even with nothing plugged into the analog inputs I'm reading between 1 and 2 volts.
Anybody have an idea how to fix this ?
"Floating" pins (connected to nothing) pick up hash from the environment.
This is not a fault (well, maybe your fault).
The analogue pin returns a radom value, usually around 400.
Any resistor to ground (e.g. 10k) will stop this.
Leo..
is it necessary to use 10k value resistor ? because i connected 1k but nothing happen
Any value from 0ohm (short/wire) to >10Megohm from analogue pin to ground will return an A/D value of zero.
Check your code and wiring.
Post a picture and the code (wrapped in code tags) if you're not sure.
Leo..
