I'm building a little MIDI controller and using Hairless to convert the serial. When I start hairless up, it gives me errors while I turn the pot. If I connect the 5V jumper to the reset pin and back, it starts working (sending out standard CC, just as I would like). That is, until I close and open the MIDI port again, in which case I have to move the jumper again. I don't get this - the analog pins normally work fine (I tried the analog read sketch) and moving the 5v jumper to any other pin and back doesn't work - reset only. I don't know what the reset pin's for, and I don't know if this is common, but it seems very odd to me.
Is my Uno broken? How can I fix this? Out of interest, what is the reset pin for?
