Hello, and good afternoon. I'm about to wrap up the conversion of all my game pads and flightsticks to Bluetooth after solving many of my own issues I am on one last problem.
My problem is the joystick readings for them all. everything is wired and hooked up correctly as in Arduino IDE I can watch the values go up and down from 0 to 941 for both X and Y in the serial monitor but when I go over to Windows test panel and move the joystick in the up position slowly the number value goes all the way up to 127 then atad further is -127 bringing the joystick marker to the bottom of the test plane and if I continue to move the joystick up it goes all the way up from -127 and past 0 then 127 again. It does this in every single direction and all my sensors (hall effect/analog sticks)
Few things to know My old projects used Promicros (ATmega32U4)
For Bluetooth and ease of installing. I got boards that are the same size with the same pin out but use the nRF52840 ProMicro nrf52840's.
#include <Adafruit_TinyUSB.h>
Single Handed Gamepad, 15 Buttons, 1 Joystick
#include <bluefruit.h>
BLEDis bledis;
BLEHidGamepad blegamepad;
// define each function and its input pin number comments describe physical switches
#define X_PIN A2 //JOY x
#define Y_PIN A1 //JOY y
int8_t x = X_PIN;
int8_t y = Y_PIN;
hid_gamepad_report_t gp;
// LOW POWER MODE!
// Pins default to INPUT mode. To save power, turn them all to OUTPUT
// initially, so only those being used will be turn on. See:
// http://www.pjrc.com/teensy/low_power.html
#if CFG_DEBUG
// Blocking wait for connection when debug mode is enabled via IDE
while ( !Serial ) delay(10);
#endif
Serial.println("ChazronBLE");
Serial.println("------------------------------------\n");
Serial.println("FileName: Chazron.ino");
Serial.println("Go to your devices's Bluetooth settings to pair your device");
Serial.println("then open an application that accepts gamepad input");
Bluefruit.begin();
Bluefruit.setTxPower(4); // Check bluefruit.h for supported values
Bluefruit.setName("Chazron");
// Configure and Start Device Information Service
bledis.setManufacturer("InMyRoom Productions");
bledis.setModel("Chucke Ergo - nRF52840");
bledis.begin();
/* Start BLE HID
* Note: Apple requires BLE device must have min connection interval >= 20m
* ( The smaller the connection interval the faster we could send data).
* However for HID and MIDI device, Apple could accept min connection interval
* up to 11.25 ms. Therefore BLEHidAdafruit::begin() will try to set the min and max
* connection interval to 11.25 ms and 15 ms respectively for best performance.
blegamepad.begin();
/* Set connection interval (min, max) to your perferred value.
* Note: It is already set by BLEHidAdafruit::begin() to 11.25ms - 15ms
* min = 9*1.25=11.25 ms, max = 12*1.25= 15 ms
/* Bluefruit.Periph.setConnInterval(9, 12); */
// Set up and start advertising
startAdv();
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
Bluefruit.Advertising.addAppearance(BLE_APPEARANCE_HID_GAMEPAD);
// Include BLE HID service
Bluefruit.Advertising.addService(blegamepad);
// There is enough room for the dev name in the advertising packet
Bluefruit.Advertising.addName();
/* Start Advertising
* - Enable auto advertising if disconnected
* - Interval: fast mode = 20 ms, slow mode = 152.5 ms
* - Timeout for fast mode is 30 seconds
* - Start(timeout) with timeout = 0 will advertise forever (until connected)
* For recommended advertising interval
* https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
// nothing to do if not connected or
if ( !Bluefruit.connected() ) return;
int val = analogRead(A2);
int val2 = analogRead(A1);
gp.x = analogRead(x);
gp.y = analogRead(y);
Serial.print("X: ");
Serial.println(val);
Serial.print("Y: ");
Serial.println(val2);
//delay(500);
blegamepad.report(&gp);
I had thought that originally but yields the same results.
I did some reading about mapping the values.
map(value, fromLow, fromHigh, toLow, toHigh)
Using the serial monitor to get actual values and using those values to get the values that I actually want but when I input it in my code the joystick no longer reads anything at all. I will include code with map added maybe im just putting it in wrong.
BLEDis bledis;
#define X_PIN A2 //JOY Y
#define Y_PIN A1 //JOY X
int16_t x = X_PIN;
int16_t y = Y_PIN;
// LOW POWER MODE!
#if CFG_DEBUG
#endif
Bluefruit.begin();
bledis.begin();
/* Start BLE HID
blegamepad.begin();
startAdv();
void startAdv(void)
x = map(X_PIN, 0, 1024, -32768, 32768);
y = map(Y_PIN, 0, 1024, -32768, 32768);
//delay(500);
I'm seeing that. Been a real headache. I'm a fool and didn't realize how different these boards really are. They may have the same size and pin out but the chips differ and I have only dealt with promicros with ATmega32u4 so this is different or I'm just so lost I don't know what I'm doing anymore.
I have 11 different 3d printed gamepads/flightsticks many are yearsss old and I've gone through many wires and boards due to wear and tear, damage, neglect, cats...... Wireless is needed haha.
