Hi Guys, new to this forum. Is there a way to get at least 4 analog outputs that are bipolar (+/-) 10 volts?
This needs to be at least 20 htz.
Christian
Christian
A very convenient way to generate that voltage is to use a variant of the MAX232 chips. The "original" will do, which is a low cost part.
They will drive just around +/-10V upto 100kHz @ around 20mA. Need 4 (I think) capacitors; there are versions that have internal capacitors, but they are significantly more expensive.
The chips also contain "receivers"; sometimes you will find a surprising use as inverter or buffer for them ...
Darn! The OP needs ANALOG voltage.
But hey... now we can at least have a +/- 10 Volts PWM... so proceed as usual...
How much current do you need to supply at +/-10V? Where are these analog outputs going?
By "20 Hz" do you mean you have to generate sinusoids between -10V and 10V at frequencies up to 20 Hz, or do you want to be able to update the analog output from one value to another within 50ms?
Check out our new shield: http://www.ruggedcircuits.com/html/gadget_shield.html
