Analog Pin as Serial interface
Hello,
I have little trouble about the possibility to use Analog IN Pins (A0 to A5) on Arduino UNO as RX/TX.
Your support is requested.
Thank you for all.
What have you tried sofar?
what did work?
what not?
Tip: you can refer to the analog pins as pin 14-19 .
All Digital Pins are already used and i still need one Serial port. But i have only the Analog IN available.
So my question is :
1/ Can i use Analog IN as Serial port?
2/ How ?
Thx.
No. But the analog pins are also digital pins. They are aliased using A0, A1, etc. Just use An where you would use n in the SoftwareSerial constructor call.
Thx PaulS for your reply.
