Hey everyone, I'm looking for some advice on a project. Keep in mind I'm new when it comes to understanding circuits/electrical components
Basically I'm trying to place a MOSFET in between an inverter (110-120v) and some EL wire to allow full adjustment to the intensity of the light based on the output from an analog pin. I'm a bit confused as to whether a MOSFET alone will be able to perform the task. I can't find a MOSFET that will work with a 120v source that also has a gate range of 0-5v (or in other words the arduino can fully open the MOSFET).
There is a very likely possibility that I'm misunderstanding the data sheets and that there are MOSFETs that will work with an arduino. I currently have a TRIAC on order but that will only allow the arduino to control the EL wire to be on or off.
EL wire requires a driver/inverter that can provide 400-2000 Hz, 60-120VAC (that's RMS not peak-to-peak!) Higher frequency/voltage results in a brighter wire
EL wire is capacitive, and cannot be PWM'ed or easily dimmed
Google "dim EL wire", you will find what you need.
Are you just pointing out the potential issue with the inverter or something else when I said "on or off"?
I've heard about the possible concerns of running the inverter without the load of the EL wire connected but I haven't seen any actual manufacturer warnings or actual issues online.
Krzr93:
Yes to both, I think.
What's your level of experience with triacs?
Krzr93:
The issuing issue that I was angling at [ ] is how the inverter would perform given a phase controlled input.
It may be possible to do AC phase control of the inverter output, but the freqs mentioned by sonnyyu, 400-2000Hz, are pretty fast. All I've ever done is 60Hz.
