Analog read fluctuating
Hi
i am reading the analog value from my arduino uno
but the read value is fluctuating so much
to illustrate :
1.17
1.17
1.17
1.17
1.30
1.30
1.17
1.17
but the real value which is seen on the sensor screen is 1.17 ;
how can i fix the issue ?
can any filtering circuit do this job ?
my code
  // initialize serial communication at 9600 bits per second:
  Serial.println("CLEARDATA");
  Serial.println("LABEL,Time,conductivity");
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A2);
  int row=0;
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = sensorValue * (5/1023.0);
  float current = (1000*voltage)/46.7 ;
  float conductivity = (current-4)*20/16 ;
  // print out the value you read:
  Serial.print("DATA,TIME, ");
  Serial.println(conductivity);
  row ++;
  ms1++;
my wiring diagram is in the attachment.
YOu can smooth the analogRead by making multiple e.g. 16 measurements and average them
float sum = 0;
for (uint8_t i = 0; i< 16; i++) sum += analogRead(A2);
sum /= 16;
(powers of 2 divide faster)
Try printing out the raw value of the A/D read to see the true size of these fluctuations. Then we can see if they are reasonable or not.
The actual read value is only fluctuating 1 count.
A change of 1 count causes your conductivity to change by 0.13.
Yes that is what I was getting at. Any A/D conversion can only be consistant to +/- one binary bit. It is not like the OP said "so much".
Maybe an algorithm that looks for a certain number of identical readings and use it instead of averaging.
something like running-median ?
