Analog read from 4051 mux act strange
Hi
Couldn't find a similar case in this forum so I post my question:
I'm working on a midi project, and try to digital read 4 buttons and analog read 11 potentiometers which 3 of them connected directly to the Arduino and other 8 via 4051 mux to A0 input the board.
The digital Read works fine, and so as analog read which is not from the mux, but something wrong with the mux readings. Only one potentiometer (the one that goes to input 000 of the mux) is being read, and with wrong values, while the other potentiometers aren't being read at all (or, at least, I can't tell if they are because the midi massage isn't being sent).
Some checks I've already done:
*I used a voltmeter and they all work fine electronically (the produce variable output voltage).
*The calcAvg function goes over all 11 values of the array
Thank you very much
*My Code:
// MIDI Library - Version: Latest
#include <MIDI.h>
// MIDI enable pin, avoids conflict of Serial between USB for programming and DIN MIDI I/O
#define MIDI_ENABLE 12
#define NUM_OF_ANALOG_INPUTS 4
#define NUM_OF_DIGITAL_INPUTS 4
#define NUM_OF_MUX_READ 8;
#define NUM_OF_READ 5;
// Variables
// define variables and arrays for the controller data
int AnalogValue[11] = {0,0,0,0,0,0,0,0,0,0,0};
int TotalValue[11] =  {0,0,0,0,0,0,0,0,0,0,0};
int AvgArray[11] =  {0,0,0,0,0,0,0,0,0,0,0};
int lastAnalogValue[11][5] ={{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0}
 ,{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0}};
// select the midi Controller Number for each input
int midiCCselect[6] = {1,2,3,4,5,6};
// select threshold for each analog input
int thresh[11] = {0,0,0,0,0,0,0,0,0,0,0};
//define array for digital input status
int DigitalValue[4] = {LOW,LOW,LOW,LOW};
//define array for digital input last status
int LastDigitalValue[4] = {LOW,LOW,LOW,LOW};
MIDI_CREATE_DEFAULT_INSTANCE();
static const unsigned ledPin = 13;      // LED pin on Arduino Uno
const int channel = 1;
    pinMode(ledPin, OUTPUT);
  //digital pins
    pinMode(2, INPUT_PULLUP);
    pinMode(3, INPUT_PULLUP);
    pinMode(4, INPUT_PULLUP);
    pinMode(6, INPUT_PULLUP);
  //mux selectors
    pinMode(8, OUTPUT);    // s0
    //digitalWrite(8, LOW);
    pinMode(9, OUTPUT);    // s1
    pinMode(10, OUTPUT);    // s2
  MIDI.begin();
  //  MIDI.begin(4);                      // Launch MIDI and listen to channel 4
  void AnalogUpdate(int idx, int readnum) { //this func store analog read value in the analog values array;
       lastAnalogValue[idx][readnum] =AnalogValue[idx];
       return;
//End AnalogUpdate
  void AvgCalc(int idx) { //this func calc an avarage of 5 read form the pin and send midi accordingly
    int tmpTotal = 0;
    int tmpAvg = 0;
    for(int i=1;i<5;i++) {
      tmpTotal = tmpTotal + lastAnalogValue[idx][i];
    tmpAvg=tmpTotal/NUM_OF_READ;
      if((tmpAvg < AvgArray[idx] -1) || (tmpAvg > AvgArray[idx] +1)){
               //send control change on cc#i
                MIDI.sendControlChange(16 +idx ,AnalogValue[idx],channel);
                pinMode(ledPin,HIGH);
      AvgArray[idx]=tmpAvg;
      return;
int j=0;
int readnum=0;
int readn=0;
//Analog loop
    for(int i=0;i<NUM_OF_ANALOG_INPUTS;i++){ //this pard is the mux reading
           if(i == 0){
            // MIDI.sendNoteOn(10, 100, 12);
              for(readnum=0; readnum < 5; readnum++){
                digitalWrite(8,LOW); //000
                digitalWrite(9,LOW);
                digitalWrite(10,LOW);
                lastAnalogValue[i+j][readnum] = analogRead(i)/8;
                j++;
                digitalWrite(8,LOW); //001
                digitalWrite(10,HIGH);
                j++;
                digitalWrite(8,LOW); //010
                digitalWrite(9,HIGH);
                j++;
                digitalWrite(8,LOW); //011
                j++;
                digitalWrite(8,HIGH); //100
                j++;
                digitalWrite(8,HIGH); //101
                j++;
                digitalWrite(8,HIGH); //110
                j++;
                digitalWrite(8,HIGH); //111
                delay(20);
                j=0;
              for(int k=0;k<8;k++){ //calac avarage for each mux read
                AvgCalc(i+k);
              delay(100);
           else{ //this pard read the other analog inputs a1 to a4
             j=7;
             for(readn=0; readn<5; readn++){
              AnalogValue[i+j] = (analogRead(i))/8;    // read the value from the analog input and divide by 8 for range 0-127
              AnalogUpdate(i+j,readn);
            AvgCalc(i+j);
      delay(20);
      pinMode(ledPin,LOW);
//Digital read loop
  if(digitalRead(2) == LOW){
    MIDI.sendNoteOn(16 +2 ,100,channel);
    delay(20);
  if(digitalRead(3) == LOW){
    MIDI.sendNoteOn(16 +3 ,100,channel);
    delay(20);
  if(digitalRead(4) == LOW){
    MIDI.sendNoteOn(16 +4 ,100,channel);
    delay(20);
  if(digitalRead(6) == LOW){
    MIDI.sendNoteOn(16 +6 ,100,channel);
    delay(20);
}//End Loop
Lose the semicolons
The code is a mess.
I don't know what the the numbers all mean.
Why not give the pins nice names, and stick with then?
Why are you wasting / ignoring element zero?
Well I can't see where in the code it is supposed to be sent.
The code is way over complex for what you are trying to do. I can't see why you need:-
and the like, yes record the last value sent but why in a two dimensional array, that is simply not necessary. You also need to sent the MIDI message if the value you read this time is significantly different from what you read last time.
Why not write some simple code that will output the values read to the serial port so you can look at them on the serial monitor. Only go into MIDI when you have that working.
It would also help if you posted your schematic.
You should be using an array to set your multiplexer address, not the mess you are doing.
http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
