This code is correct and works but I need instead of calcFactor change I can do it analog with potentiometer and change to A0 (Analog read) how to do it?
//1986 Porsche 944 Turbo Speedometer Calibrator
//Public Domain
//raw 944 transmission sensor signal must be processed by external schmitt trigger
//Schmitt trigger should bypass filer and pull-up resistor
//Use LM2940-10 with decoupling caps per datasheet to power Arduino in automotive setting
//Arduino Pin 7 supplies modified signal for speedometer
const int debounce = 2500;
const int speedometerPin = 7;
const int sensorPin = 3;
int pulseState = LOW;
volatile unsigned long currentMicros = 0;
volatile unsigned long previousMicros= 0;
volatile unsigned long currentSpeed = 0;
volatile unsigned long previousSpeed = 0;
volatile unsigned long interval = 0;
unsigned long modInterval = 0;
float calFactor = .91; // decrease to slow down speedometer
// calFactor of 1 makes no change to speedometer
pinMode (13, OUTPUT);
pinMode(speedometerPin, OUTPUT);
pinMode(sensorPin, INPUT);
digitalWrite (sensorPin, HIGH);
attachInterrupt (1, iSr, FALLING);
noInterrupts();
modInterval=interval;
interrupts();
currentMicros = micros();
if (currentMicros-previousSpeed<1000000)
if (currentMicros - previousMicros>((modInterval/2)/calFactor))
{ previousMicros = currentMicros;
if (pulseState == LOW) pulseState = HIGH; else pulseState = LOW;
digitalWrite(13, pulseState); //to blink onboard LED
digitalWrite(speedometerPin, pulseState);
void iSr()
currentSpeed=micros();
if (digitalRead(sensorPin)==LOW)
if ((currentSpeed - previousSpeed) > debounce)
interval = currentSpeed - previousSpeed;
previousSpeed=currentSpeed;
