Analog read is not giving the correct waveform as that of an oscilloscope
I have this code that fetches analog input values from terminals A0, A1 and A2 of Arduino mega 2560. But, when I plot the data, it does not give the desired waveform. The desired waveform is parallel measured in the digital storage oscilloscope. I was thinking to make use of Arduino mega 2560 as an oscilloscope that can have 16 channels. Because the DSO has only 4 and for a project, I urgently need 16 channels. Would be great if the community people suggest something. Thanks.
[![Data read by Arduino-MATLAB interface][1]][1]
Below is the desired data from the oscilloscope that is measured parallel to avoid any confusion about the circuit.
[![Desired data measured parallel by an oscillopse][2]][2]
Code `
%This is a script that will plot Arduino analogRead values in real time
%Modified from http://billwaa.wordpress.com/2013/07/10/matlab-real-time-serial-data-logger/
%The code from that site takes data from Serial
clear all
close all
clc
%User Defined Properties
a = arduino('Com5')             % define the Arduino Communication port
arduino=serial('COM5','BaudRate',9600);
s1 = serial('COM5');                                                       % Define here YOUR serial port
s1.BaudRate=9600;
plotTitle = 'Arduino Data Log';  % plot title
xLabel = 'Time (s)';     % x-axis label
yLabel = 'Voltage (V)';      % y-axis label
legend1 = 'Voltage 1'
legend2 = 'Voltage 2'
legend3 = 'Voltage 3'
yMax  = 5                           %y Maximum Value
yMin  = 0                       %y minimum Value
plotGrid = 'on';                 % 'off' to turn off grid
min = 0;                         % set y-min
max = 5;                        % set y-max
delay = .01;                     % make sure sample faster than resolution
%Define Function Variables
time = 0;
data = 0;
data1 = 0;
data2 = 0;
count = 0;
%Set up Plot
plotGraph = plot(time,data,'-r' )  % every AnalogRead needs to be on its own Plotgraph
hold on                            %hold on makes sure all of the channels are plotted
plotGraph1 = plot(time,data1,'-b')
plotGraph2 = plot(time, data2,'-g' )
title(plotTitle,'FontSize',15);
xlabel(xLabel,'FontSize',15);
ylabel(yLabel,'FontSize',15);
legend(legend1,legend2,legend3)
axis([yMin yMax min max]);
grid(plotGrid);
tic
while ishandle(plotGraph) %Loop when Plot is Active will run until plot is closed
%          dat = readVoltage(a,'A0')* 0.48875855327; %Data from the arduino
%          dat1 = readVoltage(a,'A1')* 0.48875855327;
%          dat2 = readVoltage(a,'A2')* 0.48875855327;
         dat = readVoltage(a,'A0')* 1; %Data from the arduino
         dat1 = readVoltage(a,'A1')* 1;
         dat2 = readVoltage(a,'A2')*1;
         count = count + 1;
         time(count) = toc;
         data(count) = dat(1);
         data1(count) = dat1(1)
         data2(count) = dat2(1)
         %This is the magic code
         %Using plot will slow down the sampling time.. At times to over 20
         %seconds per sample!
         set(plotGraph,'XData',time,'YData',data);
         set(plotGraph1,'XData',time,'YData',data1);
         set(plotGraph2,'XData',time,'YData',data2);
          axis([0 time(count) min max]);
          %Update the graph
          %pause(delay);
  end
delete(a);
disp('Plot Closed and arduino object has been deleted');`[code][code][i][b][code]
[/b][/i][/code][/code][/code]
Most Arduinos have only one ADC, so it is not possible to read multiple channels in parallel.
You can buy 16 channel DSOs and 16 channel parallel ADC samplers.
