Analog read three sensors
I want to read values from three sensors which are connected to analog pins. But when affecting one of the sensors, the other ones values also changing, how to avoid that?
Thanks
Have a lower impedance for the sensors. Or read the sensor twice and discard the first reading.
Connections between sensors and the board could cause this problem?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Can you please post a copy of your sketch, using code tags? Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom....... :)
EdgarasA3: Connections between sensors and the board could cause this problem?
Look, when you ask for advice you do not simply ignore it or people (me) are going to get cross. I told you what would work in over 95% of these cases. So try what I said and report back if it does not work.
