Analog read value inconsistent
I am testing out a display that uses I2C. I am able to get the panel to update using values from the analog pin connected to a 10k pot. They are both powered with the 5v from the arduino.
When I connect the display and do an analog read I get varying numbers within about a 50 value range (not changing the pot position). When the display is not connected I get a constant value.
I have tried different pins with the same result.
Here is the display power requirements:
Power Supply: 4-30 VDC.
Current Consumption: 190 mA max.
I'm pretty new, to this so it might be something obvious so I thought I would ask.
Thanks
OF WHAT ?
Where's your code ?
Thanks for responding, here is the relevant code:
#include <Wire.h>
boolean found=false;
byte panelAddress, panelError;
byte myBytes[8];
byte negative=0x2D;
byte positive=0x2B;
byte decimal=0x2E;
byte space=0x20;
byte expoChar=0x45;
char buffer[25];
int potpin = A0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
float reading;
  Wire.begin();
  Serial.println("\nI2C Panel Meter");
  if(!found){
    findI2Cdevice();
  }else{
    val = analogRead(potpin);
    Serial.print("Analogue Pin: ");
    Serial.println(val);
    reading=convertAnalog(val);
    prepareValue(reading);
    myBytes[0]=panelAddress;
    myBytes[1]=0x00;
    Wire.beginTransmission(0x08);
    Wire.write(myBytes[0]);
    Wire.write(myBytes[1]);
    Wire.write(myBytes[2]);
    Wire.write(myBytes[3]);
    Wire.write(myBytes[4]);
    Wire.write(myBytes[5]);
    Wire.write(myBytes[6]);
    Wire.write(myBytes[7]);
    panelError=Wire.endTransmission(true);
    //Serial.println("");
    if(panelError!=0){
      Serial.println("Panel Error: ");
      Serial.println(panelError);
    }else{
      //Serial.print("Sent(");
      //Serial.print(String(panelAddress, HEX));
      //Serial.print(") :");
      for(int x=0;x<8;x++)
           Serial.print(myBytes[x],HEX);
       Serial.println("");
  delay(250);
I’m using an arduino mega 2560.
Here is a reading with the meter connected and working:
Analog Val: 222
Analog Val: 244
Analog Val: 227
Analog Val: 236
Analog Val: 235
Analog Val: 215
Analog Val: 232
Analog Val: 226
Analog Val: 226
Analog Val: 212
Disconnecting the Display:
Analog Val: 201
Analog Val: 201
Analog Val: 201
Analog Val: 202
Looks like you have no power supply decoupling on your display.
Did you measure the voltage at the analog input pin?
