analog read/write help
I posted about this already but have not received any help for it. Maybe its because last post i really did not know what i was doing, but its all becoming more clear. could someone give me some advice/ show me something to read that will help me come up with the solution.
I want a pot to read its value and write the speed at which the LEDs fade together. Im positive this can be done.
the code below includes what im at with a very important part of this. also it include a direction i think it would need to go to get this working. im just going to keep plugging away over here so i would really appreciate some help. thanks fellow arduino people.
int calculateStep(int prevValue, int endValue)
      int step = endValue - prevValue;
      if (step)
        step = 1020/step;
      return step;
    int calculateVal(int step, int val, int i)
if ((step) && i % step == 0)
  if (step > 0)
    val += 1;
  else if (step < 0)
    val -= 1;
//calculate step/val is the math for what controls the fade function
if (val > 255)
  val = 255;
if (val < 0)
  val = 0;
return val;
void crossFade(int color[3])
// this says that 'crossFade' controls 3 intigers and gives them the names R,G,B
  int R = color[0];
  int G = color[1];
  int B = color[2];
  int stepR = calculateStep(prevR, R);
  int stepG = calculateStep(prevG, G);
  int stepB = calculateStep(prevB, B);
  //when the loop starts over it says to move from last color value to new through the math equation
  //which is said at the bottom of the code for the loop
  for (int i = 0; i <= 1020; i++)
  // im not too sure about this.. it says value = 0 and value is less than or equal too 1020
  // and increase value
    redVal = calculateVal(stepR, redVal, i);
    grnVal = calculateVal(stepG, grnVal, i);
    bluVal = calculateVal(stepB, bluVal, i);
    // rbgVal is the calculated of fade from last value to new value, ???, and the value...
 analogWrite(redPin, redVal);
 analogWrite(grnPin, grnVal);
 analogWrite(bluPin, bluVal);
 // tell the pins to do this
 delay(fade);
 // slow this process down what ever number was given to 'fade'
//  ??delay(analogRead(sensorPin));?? maybe starting off with something like this? instead of delay(fade)
   if (DEBUG)
   if (i == 0 or i % loopCount == 0)
     Serial.print("loop/RGB: #");
     Serial.print(i);
    Serial.print(" | ");
   Serial.print(redVal);
  Serial.print(" / ");
 Serial.print(grnVal);
Serial.print(bluVal);
   DEBUG += 1;
  prevR = redVal;
  prevG = grnVal;
  prevB = bluVal;
  delay(hold);
Moderator edit: code tags added.
Read this before posting a programming question
What happens? What do you expect to happen?
what happens is you put a number = to fade. this number will determine the speed at which the colors fade together. what i want to have happen is assign pot to change this speed. maybe it needs to change the fade number? i have been working on having a pot control the delay time.
If you are going to post code, can you post code that compiles please?
sketch_oct19a.cpp: In function 'void crossFade(int*)':
sketch_oct19a:43: error: 'prevR' was not declared in this scope
sketch_oct19a:44: error: 'prevG' was not declared in this scope
sketch_oct19a:45: error: 'prevB' was not declared in this scope
sketch_oct19a:54: error: 'redVal' was not declared in this scope
sketch_oct19a:55: error: 'grnVal' was not declared in this scope
sketch_oct19a:56: error: 'bluVal' was not declared in this scope
sketch_oct19a:60: error: 'redPin' was not declared in this scope
sketch_oct19a:61: error: 'grnPin' was not declared in this scope
sketch_oct19a:62: error: 'bluPin' was not declared in this scope
sketch_oct19a:66: error: 'fade' was not declared in this scope
sketch_oct19a:74: error: 'DEBUG' was not declared in this scope
sketch_oct19a:76: error: 'loopCount' was not declared in this scope
sketch_oct19a:93: error: 'hold' was not declared in this scope
sketch_oct19a:94: error: expected `}' at end of input
We don't want to guess what your code is, we want to see it.
ok i see sorry about that i was thinking thats all that was needed.
int redPin = 11;
int grnPin = 5;
int bluPin = 6;
int potPin = A0;
int sensorValue = 0;
int outputValue = 0;
int black[3] = {255, 255, 255 };
int red[3] = { 0, 255, 255 };
int greenBlue[3] = { 255, 0, 0 };
int purplePink[3] = { 0, 255, 0 };
int tangerine[3] = { 0, 226, 255 };
int lemonLime[3] = { 0, 0, 255 };
int guesswork[3] = { 200,50,250};
int redVal = black[0];
int grnVal = black[1];
int bluVal = black[2];
int fade = 4;
int hold = 1;
int DEBUG = 1;
int loopCount = 60;
int repeat = 0;
int j = 0;
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
pinMode(redPin, OUTPUT);
pinMode(grnPin, OUTPUT);
pinMode(bluPin, OUTPUT);
if (DEBUG){
crossFade(greenBlue);
crossFade(purplePink);
crossFade(tangerine);
crossFade(lemonLime);
crossFade(red);
crossFade(guesswork);
if (step)
step = 1020/step;
return step;
if (step > 0)
val += 1;
else if (step < 0)
val -= 1;
if (val > 255)
val = 255;
if (val < 0)
val = 0;
return val;
int R = color[0];
int G = color[1];
int B = color[2];
// delay(fade); this is what works and what i put under
// before } is what im working with to control the pot
sensorValue = analogRead(potPin);
outputValue = map(sensorValue, 0, 1023, 0, 500);
delay = analogWrite( redVal, grnVal, bluVal);
if (DEBUG)
Serial.print(i);
DEBUG += 1;
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
delay(hold);
and thank you for you time :slight_smile:
Did you read reply #1?
Please read about putting your code into code tags.
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
just clicked the button the to right of it. sorry about that..
This is a cross-post isn't it?
http://arduino.cc/forum/index.php/topic,127837.0.html
Thread locked.
Please don't cross-post. Stick with one thread.
