Analog reading pulsating to zero
As you can see in the attached pic, the return value of AnalogRead(0) is pulsating from some value to zero. Sample time is 50ms.
I am using Arduino Due with MegaMoto*) shield. A0 input is supposed to read current sensing from MegaMoto. I tried to measure A0 to GND with multimeter but no pulse is detected. I have an external sensor connected to A1 and was read fine with AnalogRead(1).
What could be the cause?
Thanks!
Aisar
*) MegaMoto Robot Power Products - MegaMoto Motor Control Shield for Arduino
Do you have a very high sampling rate?
Try putting a delay(20); in the loop, to give the ADC a way to "keep up" with the demands of the program.
I don't KNOW that reading as fast as loop() can go is a problem... but think it might be.
tkbyd:
I'll try to lower the sampling rate. Now it's right under the loop(). But again, A1 is read with the same way but was fine.
Here's what I found from Arduino reference page:
It takes about 100 microseconds (0.0001 s) to read an analog input, so the maximum reading rate is about 10,000 times a second.
Connect a potentiometer to A0 and check that you can read the input.
Do you use a breadboard with bad connections ? The graph of the measurements is typical for an open input or a missing ground.
