I am trying to figure what the perfect sensor reading is to set a trigger point in another program so I set up this little bit of code to log the sensor reading every 5 minutes. But it seems like the readings are a little more up and down than they should be.
Right now the program is simply serial printing the sensor reading every 5 minutes. What I would like is have it print the average of 5 minutes of readings sampled every couple of seconds or so.
Thanks
int sensorPin = A0; // select the input pin for LDR
int sensorValue = 0; // variable to store the value coming from the sensor
Serial.begin(9600); //sets serial port for communication
sensorValue = analogRead(sensorPin); // read the value from the sensor
Serial.println(sensorValue); //prints the values coming from the sensor on the screen
delay(300000);
al_duino_nano:
Thanks
delay(300000);
Suppose you take a sample once every 100mS. In 5-minutes there are 3000 100mS periods (300 seconds in 5 minutes x 10 100mS periods/second...)
If your sensor read the maximum for every read you would see a sum of 3000 x 1023 or 3,069,000; you'll need a long or unsigned long to store 5 minutes' worth of readings.
A five minute period of sampling and averaging could be done with something like:
I'd be surprised if you really need hundreds or thousands of samples.
Perhaps you could keep a record of the last 30 reads in an array and update once every hundred milliseconds:
#define NUM_SAMPLES 30
#define SAMPLE_PERIOD 100ul
const byte sensorpin = A0;
int
sensorSum, //sum of 30 1023 readings will squeeze into an int
sensorReading,
sensorArray[NUM_SAMPLES];
float
sensorAvg;
void setup( void )
pinMode( sensorpin, INPUT );
sensorReading = analogRead( sensorpin ); //initialize the array with the first reading
for( int i=0; i<NUM_SAMPLES; i++ )
sensorArray[i] = sensorReading;
sensorSum = sensorReading * NUM_SAMPLES; //initial sum will be NUM_SAMPLES x the first reading
}//setup
void loop( void )
static unsigned long
timeSample = 0;
unsigned long
timeNow;
timeNow = millis();
if( (timeNow - timeSample) >= SAMPLE_PERIOD )
timeSample = timeNow;
sensorReading = analogRead( sensorpin ); //read the sensor
sensorSum -= sensorArray[0]; //subtract the value of the oldest table entry about to be removed
sensorSum += sensorReading; //add in the new reading
sensorAvg = (float)sensorSum / (float)NUM_SAMPLES; //compute the new average
Serial.print( "Sensor average: " ); //print it
Serial.println(sensorAvg);
for( int i=1; i<NUM_SAMPLES; i++ ) //drop the oldest reading & move every reading down one...
sensorArray[i-1] = sensorArray[i];
sensorArray[NUM_SAMPLES-1] = sensorReading; //...and add the newest reading to the end
}//if
}//loop
It should be said that it is a lot simpler, and a lot less wasteful of processor cycles, to maintain a circular buffer with simple arithmetic of indices, than actually moving readings around memory.
Dearest Blackfin or whoever might be code savvy....
Blackfins datalogging code (reposted below) works well....but the data I am looking at is time specific so I have been trying to figure how to use the time.h library to add a time stamp line to the serial print.
I have tried several times but I keep breaking the code with syntax errors and other noob mistakes.
I am trying to add at least the hour and minute of the day to each line....I have edited the original code to return fewer prints per day but that is it.
int
sensorReading,
float
sensorAvg;
void setup( void )
}//setup
void loop( void )
timeSample = 0;
unsigned long
timeNow;
timeNow = millis();
delay(172800);
}//if
}//loop
I could...but aren't there apps that will make the clock data from the computer available to the arduino? Or maybe sync to a website?
I understand that an RTC will make it more versatile and portable....but this little system will always be hooked to either my PC or laptop and the data is logged to the serial monitor.
