Analog Signal scaling both directions
I'm looking for a solution that can scale a 0-5v Signal to 0-3.3v and also the other way around.
I read quite a lot actually about op amps, but still the question remains about scaling in both directions.
Basically I'm looking for a bidirectional logic level shifter for analog signals.
Is this possible ? Does somebody have schematics, maybe on easyeda?
I'm thankful for every help that I can get. Meanwhile I will keep reading about the functionality of op amps and what can be done with it.
Regards !
A logic level is not analog.
Are you trying to turn a 0..5V analog voltage to a -3.3V..+3.3V signal?
I know that logic level is not analog, but I mean functionality wise it's basically the digital thing of what I want to do.
I want to scale 0-5V to 0-3.3V and the other way around.
0-5v -> 0-3.3v
0-3.3v -> 0-5v
Probably the best way to do this is with an Op Amp--like this:
Caveats:
  • Those resistor values might need to be different, depending on the application.
  • This assumes a frequency less than, probably around 500kHz.
  • The Op Amp supply voltage needs to be at least 1.5 to 1.75V higher than 5V [depending on how much current the Op Amp output needs to deliver [up to 5mA]. I indicated 12V, but it doesn't need to be that high -- but, the Op Amp will perform better at higher voltages [only a concern if you plan to push it to it's limits]. I would use a voltage of at least 7V
  • The Op Amp of choice must include Ground in it's Common-Mode Input Voltage Range.
  • The 0 - 5V to 0 - 3.3V case can be, in some cases, merely the voltage divider [i.e. R1 & R2]. The Op Amp provides buffering. And, buffering makes it possible to connect it to a lower impedance load, without the voltage sagging.
  • Hmmm...what did I forget...?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
What controller are/will you be using?
What is the application that needs the signal translation?
Thanks.. Tom.. :slight_smile:
Kurtisane:
But not fast, right?
Kurtisane:
0-5v -> 0-3.3v
Very simple: use a voltage divider. 10K + 5k1 will do great.
0-3.3v -> 0-5v
Use an OpAmp as suggested in #3.
wvmarle:
How can you be sure? The OP has given us no particulars. If the 0-3V must drive a low impedance, this load may alter the voltage levels on your voltage divider.
That's why I included a buffer on the output of the voltage divider, with a note qualifying it as optional, and indicating the possible inadequacy or even that. In fact, some sort of Power Amplifier may be needed--who knows?!
Kurtisane:
0-5v -> 0-3.3v
0-3.3v -> 0-5v
Please be specific: do you want to level shift a logic, digital signal? Or do you want to scale an
analog voltage.
These are done two entirely different ways.
