Try it like this?
const int Pin1 = 12; // connected to pin 7 on the H-bridge
const int Pin2 = 11; // connected to pin 2 on the H-bridge
const int enablePin = 3; // connected to pin 1 on the H-bridge
const int potPin = A0; // connected to the potentiometer's output
int motorSpeed = 0; // speed of the motor
int threshold = 90; // Move the motor when EMG signal is above this threshold. Remember it ranges 0–1023.
int oldState = 0;
unsigned long startTime;
pinMode(Pin1, OUTPUT);
pinMode(Pin2, OUTPUT);
pinMode(enablePin, OUTPUT);
//pinMode(motorPin, OUTPUT);
//pinMode(sensorPin, INPUT);
//int sensorState = digitalRead(sensorPin);
int EMGsig = analogRead(A5);
float voltage = EMGsig * (5.0 / 1023.0);
if (EMGsig > threshold) { //voltage must be tuned according to sEMG output
if (oldState > threshold) {
Serial.println("Button Pushed");
digitalWrite(Pin1, HIGH);
digitalWrite(Pin2, LOW);
analogWrite(enablePin, motorSpeed);
} // turns the motor on
startTime = millis();
oldState = EMGsig;
if (digitalRead(Pin1 == HIGH)) {
if (millis() - startTime >= 5000UL) {
Serial.println("Timer Expired");
digitalWrite(Pin1, LOW);
digitalWrite(Pin2, HIGH);
analogWrite(enablePin, 0);
Serial.print(EMGsig); Serial.print(" EMG reading, with voltage: "); Serial.println(voltage);
motorSpeed = analogRead(potPin) / 4;
-jim lee
