My project is coming along very well. Thanks in no small part to help from people here. Just a couple of things to go.
I have been trying to work out how to smooth the reads from multiple analog inputs. I can obviously find plenty of code for a single input, but not multiple inputs. And I am reluctant to have multiple almost identical code snippets if possible.
My project currently reads A0-A3 inclusive.
Any pointers to examples or references would be most helpful.
essentially you want to average the signal change over several samples.
You could do something like this to keep memory usage to a minimum Yn is the smoothed value at step n , Xn is the raw input value at step n
Yn = Yn-1 + (1/k * (Xn - Yn-1))
K Is a smoothing factor having it close to 0 or really high will influence the smoothing. having k < 1 will likely diverge.
Here is a quick table made with excel where I'm varying k from 1, 2, 3, ..
You have samples taken on the left side and in the array what the smoothing value would be based on the smoothing factor k which is at the top of the column
To generate the samples I took some random noise around the value 50 (can range between 45 and 55)
this is what it looks like:
you can see the impact of the smoothing factor.
In this formula you only need the current value on input Xn and remembering the last smoothed value Yn-1.
If what you are asking for is obtaining only 1 number smoothing the combined signal from all the input then if all your analog inputs are in the same range and related then just sum your inputs and divide by the number of inputs (i.e. Average your input) to build Xn
If what you are asking for is getting multiple smoothed values, one per each input then
Loop for i varying between 0 and number of analog inputs - 1
read analogInput[i] into an array currentInputValue[i] ,
Keep an array of previousSmoothedOutput[i]
compute in a another array currentSmoothedOutput[i] with the formula above (you can have an array of k[i] if smoothing factors need to be different for each input)
Do something with the currentSmoothedOutput array
Then move each currentSoothedOutput into previousSmoothedOutput
Go back to the loop
(Make sure all values are initialized to something meaningful the first time)
The good thing with this approach is that k can be changed in software so you can adjust the smoothing effect in software.
Wow, so many answers. Maybe I should have been more clear about what exactly I wanted to achieve.
My project currently monitors 3 inputs. It displays the inputs to an LCD as well as writing the same to a data logger. The project will eventually monitor 4 inputs.
So what I was hoping to do was smooth/avaerage each individual input and still be able to display/write the result as I am now. I don't want to avaerage all the inputs and get 1 result.
Now remember, I'm not a programmer. I have the sketch I have because of guys like you, Google, and a friend of mine who is a programmer.
Currently the sketch does what I require. I'm just hoping to make the result of the inouts a little more stable.
Still to do:
Add wifi shield go give the project a wireless web server. Display basic information.
Add MPPT control to the project. This will make it a charge controller
Add diversion control for the wind turbine.
Send the data log file to a network share after rollover for further processing.
Find an alternative for the SD card data logger as I am writing data to it twice per second. This is because the output of the wind turbine can change quickly, and I wish to capture as much data as practicle.
Ultimately I may need to move to a Raspberry Pi for coding, and use the UNO as a hardware interface only as I think I will run out of programming space on the UNO. I'll probably use Firmata for that.
So I went to put it into practice and I am having a problem.
As it is a function I have place all the code above loop setup(), but when I call a result "smoothedReading[1]" from within the void loop() the answer is zero.
