It gets better with age No it doesn't.
Hi All
So I've been testing my code for a couple of days. And I still can't get to grips with the sampling side of things.
const int NINPUTS = 4;
const byte inputPin[NINPUTS] = { A0, A4, A3, A5 };
int reading[NINPUTS];
float smoothedReading[NINPUTS];
void takeReadings() {
for(int i = 0; i<NINPUTS; i++) {
reading[i] = analogRead(inputPin[i]);
smoothedReading[i] = smoothedReading[i] * .75 + reading[i] * .25;
As I understand it.
Is the sampling side of things.
My problem is that as a non programmer I don't understand it at all. But I wish to learn.
If someone can please explain to me what is happening, I would have a greater understanding of what to adjust, and what effect it has on the outcome.
Regards
Fred
You tell us what 'you' think is going on with each line of code:
reading[i ] = analogRead(inputPin[i ]);
smoothedReading[i ] = smoothedReading[i ] * .75 + reading[i ] * .25;
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
Declare NINPUTS as a constant integer with a value of 4
Declare input[NINPUTS] with the values of the A0, A4, A3,A5 and the values are a constant byte
Declare reading[NINPUTS] as an integer
Declare smoothedReading[NINPUTS] as a float
Declare the function void takeReadings()
I don't know. Spomething to do with counting the readings I guess
I don't know. Making reading[i] = analogRead(inputPin[i]). But why would you do that
I don't know. Making smoothReading[i] = smoothReading[i] and some confusing equation.
So here's what I don't understand, what is [i]
? And how do we know how many readings we are taking per input.
That should be good for a giggle. But I'm not a programmer, and I still struggle with the correct terms.
Regards
Fred
It's math. You're taking 25% of the current reading, and adding 75% of the previous reading. If it were 50/50 it would be a standard average. Get it? Then rinse and repeat. The result becomes the previous reading for the next round.
