Analog softwareserial
Hello,
I was wondering if it's possible to use softwareserial with a analog pin.
Any info?
Can't see why not.
How do i need to define analog pin 1? A1?
A1 or 15, on a Duemilanove/UNO. It has a different number on a Mega, but the same alias (A1).
hmm i tried your trick with my Serial LCD with the following code, however it doesn't work
define txPin A1
SoftwareSerial LCD = SoftwareSerial(0, txPin);
void setup() { Serial.begin(9600); pinMode(txPin, OUTPUT); LCD.begin(9600); } void loop(){ }
Any suggestions?
It is not a trick it is what you need to do. What arduino are you using? Try putting 15 directly in.
It isn't a trick, and it isn't mine, but apart from that, in what way didn't it work?
varuninnz: hmm i tried your trick with my Serial LCD with the following code, however it doesn't work
define txPin A1
Any suggestions?
I suggest you post all your code. That doesn't compile.
sketch_oct13e:1: error: 'SoftwareSerial' does not name a type
sketch_oct13e.cpp: In function 'void setup()':
sketch_oct13e:6: error: 'LCD' was not declared in this scope
Read this before posting a programming question
