Hello y'all
I am fairly new to Arduino, but love it. I need to use a linear actuator for some home automation stuff. I got it working with two buttons based on wiring and code from Push Button Control with Arduino | Firgelli Automations . one button out; other button in. pretty straight forward. I did this just to see how that worked. this is all done on an Arduino uno. Now I want to recreate this with an Arduino wifi and make the buttons digital buttons on the IoT Remote app for iPhone. Now I will post the diagram I used for wiring and the code that is from GitHub that goes along with it.
https://cdn.shopify.com/s/files/1/0615/2193/files/push_button_arduino_motor_driver_bb_10f1ccde-8f3f-4db5-8743-5cc3f5bacc73_large.png?v=1591745921
that was the image also found in the original link and here is the code copied form the link as well as being found on GitHub.
/* Firgelli Automations
* Limited or no support: we do not have the resources for Arduino code support
* Program enables momentary direction control of actuator using push button
int RPWM = 10; //connect Arduino pin 10 to IBT-2 pin RPWM
int LPWM = 11; //connect Arduino pin 11 to IBT-2 pin LPWM
int downPin = 12;
int upPin = 13;
int Speed = 255; //choose any speed in the range [0, 255]
pinMode(RPWM, OUTPUT);
pinMode(LPWM, OUTPUT);
pinMode(downPin, INPUT_PULLUP);
pinMode(upPin, INPUT_PULLUP);
if(digitalRead(upPin)==LOW){ //check if extension button is pressed
analogWrite(RPWM, 0);
analogWrite(LPWM, Speed);
else if(digitalRead(downPin)==LOW){ //check if retraction button is pressed
analogWrite(RPWM, Speed);
analogWrite(LPWM, 0);
else{ //if no button is pushed, remain stationary
This is not my design or code so if there is anything I could have done better please let me know. in conclusion I want to make this a low key IoT solution. thanks in advance.
Ahab
