Hi, I have been trying to set up an arduino to measure Infra Red (how much) using an Osram SFH 203 FA but with ZERO results !!
I have tried a few variations but basically I am using the AnalogReadSerial sketch with the photodioide positive going to arduino analog pin 0 and the photodiode negative going to arduino GND - clearly wrong? I just get a bunch of values the same as if nother is connected.... any pointers would be great
Also, how are you illuminating the photodiode? Do you have a strong source of IR light, as visible light is being filtered out. The sun should work well (if it's daylight where you are )
No change but I tried the same setup on a 328 board (I was using a 168) and now I'm getting results The value is high when the is no IR and low when there is... is this right?
Not sure about the 168 board - it should work the same I guess?
Odd...it should work the same. Though the circuit is very sensitive to leakage currents (we're in the microamps range here) so perhaps there is enough part-to-part variation to allow one board to work and another not.
Really, a more robust solution for photodiode interfacing is the transimpedance amplifier, but I figured a simple resistor circuit would be enough for a short-term test:
Thanks for your help - very much appreciated. My ultimate goal is to record when a wood burner is on and to what degree (without contact) - I figured infra red is the way to go but I need to do some testing - now that I can get some sort of sensor output I can see how it might help me record the info I'm looking for.
