Analog Voltage Divider V2 from DF Robot
I have a sensor with an analog output between 0-10V that I want my arduino uno to read. I don't want to build a voltage divider (I know, it's super easy). Can I buy and use this one instead?
http://www.dfrobot.com/index.php?route=product/product&keyword=dfr0051&category_id=0&description=1&model=1&product_id=90
Yes you can use the linked item but as it is designed to read up to 25V and your only using 10V there will be some loss of resolution in your analogue readings.
Is it worth it for the sake of 2 suitable resistors?
